New Reply
Quick way to tell if two rings are isomorphic?
Share Thread Thread Tools
May15-12, 03:48 PM   #1
Say if the following rings isomorphic to [itex] \mathbb{Z}_6 [/itex] (no justification needed);
1) [itex] \mathbb {Z}_2 \times \mathbb {Z}_3 [/itex]
2) [itex] \mathbb {Z}_6 \times \mathbb {Z}_6 [/itex]
3) [itex] \mathbb {Z}_{18} / [(0,0) , (2,0)] [/itex]
3. The attempt at a solution
I know how to tell if two rings AREN'T isomorphic - find an essential property that one ring has that another one doesn't. For example part 2), [itex] \mathbb {Z}_6 \times \mathbb {Z}_6 [/itex] has 36 elements, whereas [itex] \mathbb {Z}_6 [/itex] has 6.
But then, how do I show the other two?
My notes say the first one is isomorphic to [itex] \mathbb {Z}_6 [/itex] because 2 and 3 are coprime. But how can it justify that so quickly? Because they are coprime both rings have the same characteristic (i.e. n.1 = 0 for n ≥ 1 in both rings). But is that enough to conclude that they are isomorphic?
And for the last one, where can I begin?
If I can show both rings are generated by their 1, and both rings have the same characteristic, they should be isomorphic right?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
May15-12, 03:52 PM   #2
Recognitions:
Homework Helper Homework Help
The first one you can do using the Chinese Remainder Theorem if you've seen it. If not,
This is a good way to do it. In particular if something is isomorphic to Z6 it should be really easy to construct the isomorphism and prove that it's an isomorphism
Your third one doesn't seem to make any sense though, since Z18 doesn't contain any elements called (0,0) or (2,0) in any standard notation that I have seen
New Reply
Thread Tools
Similar Threads for: Quick way to tell if two rings are isomorphic?
Thread Forum Replies
Showing two rings are not isomorphic Calculus & Beyond Homework 2
Isomorphic rings Linear & Abstract Algebra 4
Isomorphic rings Calculus & Beyond Homework 1
Isomorphic rings Calculus & Beyond Homework 0
How to show two rings are not isomorphic Linear & Abstract Algebra 11
