Electric field by infinite line of charge
The problem involves calculating the electric field generated by an infinitely long line of charge with a given linear charge density λ. The electric field is to be determined at a specific point in space defined by coordinates X = x(x') + y(y') + z(z').
  • Mathematical reasoning, Assumption checking
  • Participants discuss the setup of the electric field equation and the integration limits. There is a focus on the expression for the differential electric field dE and whether the terms in the denominator are correctly represented. Some participants question the treatment of the limits of integration and the resulting calculations.
The discussion is ongoing, with participants providing feedback on each other's attempts. There is a suggestion to reconsider the terms in the denominator of the electric field expression, indicating a productive exploration of the mathematical setup.
Participants are navigating through the implications of integrating over an infinite range and the assumptions made regarding the coordinate system and the representation of distances in the electric field formula.
Sam99
Given an infinitely long line of charge density λ extended along the x-axis, what is the electric field at a point X = x(x')+y(y')+z(z') (in space)?
E = kq / r^2, dq = (lamda)dx
dE = kλ ∫ [x(x')+y(y')+z(z')- x(x')] dx / [(y^2) +(z^2)]^(3/2) (integral from -∞ to +∞)
I end up getting 0 because -∞ + ∞ equals 0?
Welcome to PF!
Hi Sam99! Welcome to PF! :smile:
(try using the X2 button just above the Reply box :wink:)
Sam99 said:
dE = kλ ∫ [x(x')+y(y')+z(z')- x(x')] dx / [(y2) +(z2)]3/2 (integral from -∞ to +∞)
shouldn't there be an x2 on the bottom also? :redface:
Thanks!
I don't think so because I'm using (x-x')/ |x-x'|^3.
would that be right?
yes, but there's still a difference in x, which has to go on the bottom
  • · Replies 28 ·
  • · Replies 18 ·
  • · Replies 36 ·
