Finding final temperature of a mixture
The problem involves calculating the final temperature of a mixture formed by adding steam at 100°C to ice at -40°C. The context includes concepts from thermodynamics, specifically heat transfer and phase changes.
  • Mixed
  • Participants discuss the energy balance between the steam and ice, using equations related to heat transfer. There are attempts to set up equations based on the heat gained by the ice and the heat lost by the steam. Some participants question the assumptions made about the states of the substances and the signs of the heat terms.
The discussion is ongoing, with participants sharing their calculations and questioning the correctness of their approaches. There is acknowledgment of mistakes in sign conventions and specific heat values. Some participants express confusion about the expected final temperature and seek further clarification.
Participants note discrepancies between their calculated results and the answer provided by the teacher, indicating a need for further exploration of the problem setup and assumptions.
MixedUpCody
calculate the final temperature when 20 grams of steam at 100°C is added to 100 grams of ice at -40°C.
Q=mcΔt and Q=ML
I tried solving this problem using -ΔQheat = ΔQcold, but the final temperature that I found was past 100 °C which is impossible because the steam's temperature is only at 100°C. I believe I need to find how much of the ice actually turns into water and how much of the steam actually condenses into water but I don't know how to go about doing that. Thank you for the help.
Welcome to PF!
Hi MixedUpCody! Welcome to PF! :smile:
I believe I need to find how much of the ice actually turns into water and how much of the steam actually condenses into water …
No, you can assume that all the steam and ice ends up at the same temperature and in the same state.
Show us your full calculations, and then we'll see what went wrong, and we'll know how to help! :smile:
Hi,
Thank you for the fast response.
This is what I had:
Qc = mcΔt + mL + mcΔt = (0.1)(2090)(0-(-40)) + (0.1)(3.33 x 10^5) + (0.1)(4.19)(T-0)
= 41660 + 0.419T
Qh = mL + mcΔt = -[(0.02)(22.6 x 10^5) + ( 0.02)(4186)(T-100)]
= -(83.72T + 36828)
when I set them equal to each other, T came out to be -932.8 °C
MixedUpCody said:
Qc = mcΔt + mL + mcΔt = …
= 41660 + 0.419T
Qh = mL + mcΔt = …
= -(83.72T + 36828)
no, that minus shouldn't be there :redface:
the first one is energy gained by the ice
the second is energy lost by the steam …
they should both be positive, shouldn't they?​
that's true. I don't know why I'm hung up on the negative from the -ΔQh = ΔQc equation. If I don't put the negative there the answer is 58°C, but the answer my teacher gave me in class was 23.4°C. The teacher didn't really show us how to get that answer,. Would you mind helping me with this? Thank you
Hi MixedUpCody! :smile:
(just got up :zzz:)
= 41660 + 0.419T
= -(83.72T + 36828)
why are you using 4.19 and 4186 for the same specific heat? :wink:
HI,
I see...lol..I'll try again with the same number =)..thank you
