| New Reply |
Formula for sum of digits of a number |
Share Thread | Thread Tools |
| May19-12, 09:13 PM | #1 |
Any ideas on this? I googled it and got only answers inolving Excel, C++, etc...
A formula for finding the digit sum of a 2-digit number, or only a 3-digit number, would also be interesting. I thought I had a start with this: For a 2-digit number xy, the sum of the digits = [itex](\frac{x}{10})\lfloor[/itex] + something. But I don't know how to isolate y. |
| May19-12, 09:44 PM | #2 |
The best way to answer this for any base is to use the DIV\MOD algorithm. This will generate each digit for each base-position for any base and then you can simply sum all the base-position components and get an answer. You can apply this say for a number in base 2, base 16, or base 10. From the sounds of it, you want to apply this algorithm to base 10. Also I'm going to assume you have a whole number: if you don't just remove the remainder (term after the decimal point) and treat this result as a normal whole number. Take a look at this: http://www.cut-the-knot.org/recurrence/conversion.shtml |
| May19-12, 10:30 PM | #3 |
Well, I'm not very advanced (AB calc in high school) so I can't completely understand the article, but it seems to be a way to find the digit sum using a computer? To clarify, I'm wondering if it's possible to have a formula that can be done with pencil and paper, not computers.
| May20-12, 12:06 AM | #4 |
Formula for sum of digits of a numberTake a number n. Do the following until you get n = 0. Set i = 1 Calculate a(i) = n MOD 10. Let n = n - a(i). n = n / 10. If n = 0 then we are done. If not then increase i by 1 and go back to the previous step. Then if you want the sum simply add up all the a(i)'s and that will give you your sum. This is for base-10, but if you want to do it for any base then just replace 10 with the base you are working with. Quick example. Let n = 231. a(1) = 231 MOD 10 = 1. 231 - 1 = 230. 230/10 = 23 which is not zero so i = 2. a(2) = 23 MOD 10 = 3. 23 - 3 = 20. 20/10 = 2 which is not zero so i = 3. a(3) = 2 MOD 10 = 2, 2-2 = 0, 0/10 = 0 so we stop. Now add up all a(i)'s to get a(1) + a(2) +a(3) = 1 + 3 + 2 = 5 which is what we expect. |
| Mar20-13, 08:50 PM | #5 |
About thirty minutes of non-continuous free time and a half sheet of paper gave me this:
For any whole number "x": 1 digit: x 2 digits: ([itex]\left\lfloor[/itex][itex]\frac{x}{10}[/itex][itex]\right\rfloor[/itex]) + (x -10([itex]\left\lfloor[/itex][itex]\frac{x}{10}[/itex][itex]\right\rfloor[/itex])) ... After awhile, I realized I could combine like terms, and this is what I got: x - 9([itex]\left\lfloor[/itex][itex]\frac{x}{10}[/itex][itex]\right\rfloor[/itex]) - 9([itex]\left\lfloor[/itex][itex]\frac{x}{100}[/itex][itex]\right\rfloor[/itex]) - 9([itex]\left\lfloor[/itex][itex]\frac{x}{1000}[/itex][itex]\right\rfloor[/itex]) - 9([itex]\left\lfloor[/itex][itex]\frac{x}{10000}[/itex][itex]\right\rfloor[/itex]) ... For powers of ten where [itex]\frac{x}{10^{n}}[/itex] is less than 1, those items become 0. To use this formula quickly, you may wish to use decimals and do the floor function in your head. i.e.: Find the sum of the digits of 345854: 345854 - 9(34585) - 9(3458) - 9(345) - 9(34) - 9(3) = 29 |
| May12-13, 08:09 PM | #6 |
Perfect! So it could be expressed as this:
latex.codecogs.com/gif.latex?x%20-%209\sum_{n=1}^{\infty}{\left%20\lfloor%20\frac{x}{10^n}%20\right%20\rf loor} |
| New Reply |
| Tags |
| digit sum |
| Thread Tools | |
Similar Threads for: Formula for sum of digits of a number
| number minus sum of digits is dividable by 9 | General Math | 7 | ||
| Divisibility by 11 for all palindromes with an even number of digits | Calculus & Beyond Homework | 6 | ||
| A three-digit number is drawn out of the digits from 0-9. | Set Theory, Logic, Probability, Statistics | 1 | ||
| Number of digits in n! | Programming & Comp Sci | 8 | ||
| Question about determining digits of a number | Precalculus Mathematics Homework | 1 | ||
