So, no prefixes...Do planes in higher dimensions satisfy Euclid's definition?
The discussion centers on the definition of planes as described by Euclid and its applicability in various dimensions, particularly R^3 and R^4. The interpretation suggests that a plane is a flat surface where a line passing through any two points on it coincides with the plane at infinitely many points. This definition holds true across dimensions, including R^1, R^2, and R^n. The formal approach to demonstrate this involves showing that the line is perpendicular to the normal vector of the plane and satisfies the plane equation.
  • Understanding of Euclidean geometry and Euclid's definitions
  • Familiarity with Linear Algebra concepts, particularly planes and vectors
  • Knowledge of dot products and normal vectors in n-dimensional space
  • Basic comprehension of Cartesian coordinates and equations of planes
  • Study the properties of planes in R^n, focusing on their geometric interpretations
  • Learn how to derive the equation of a plane using normal vectors and points
  • Explore the concept of linear independence and its relation to planes in higher dimensions
  • Investigate the implications of dimensionality on geometric definitions in mathematics
Mathematicians, students of Linear Algebra, and educators seeking to deepen their understanding of geometric definitions and their applications across different dimensions.
AlonsoMcLaren
A problem in Linear Algebra by Jim Hefferson:
Euclid describes a plane as \a surface which lies evenly with the straight lines
on itself". Commentators (e.g., Heron) have interpreted this to mean \(A plane
surface is) such that, if a straight line pass through two points on it, the line
coincides wholly with it at every spot, all ways". (Translations from [Heath], pp.
171-172.) Do planes, as described in this section, have that property? Does this
description adequately de fine planes?
The answer is ambiguous:
Euclid no doubt is picturing a plane inside of R^3. Observe, however, that both R^1 and R^2 also satisfy that definition.
So what about R^4 and beyond? Do planes in R^4 (and beyond) have the property stated above? Is this property a definition of planes in R^4 (and beyond)? Is it even a definition of planes in R^3?
Hey AlonsoMcLaren.
Just to clarify I'm interpreting the quote to mean that you have a flat surface (plane) and a line and if the line passes through any two points then the line runs through infinitely many points on the plane.
If this is the case, the answer should be used for any plane of any dimension, although the line will only run through a subset of points even though the number of points is infinite.
The way to do this formally is to show that the line is perpendicular to the normal vector and that the two points satisfy the plane equation. Showing that the direction vector of the line is perpendicular to the normal vector with two solutions to the plane equation being the two points can be expanded to show that the line crosses infinitly many points on the plane and in effect lies on the plane.
For the n-dimensional construction of a plane, use the relationship n dot (r - r0) = 0 wher dot is the dot product (Assuming cartesian/euclidean space), r is an arbitrary point to satisfy plane-equation and r0 is a specific known point on the plane. When this is 0 for a given r, then r lies on the plane.
  • · Replies 25 ·
  • · Replies 29 ·
  • · Replies 19 ·
