Is a circle still considered a surface?
  • Context: Undergrad
  • Thread starter Thread starter HAL10000
    Circle Surface
The discussion revolves around whether a circle can be considered a surface, particularly in the context of a mathematical problem involving surfaces equidistant from a point and a plane. The scope includes conceptual definitions of surfaces and mathematical reasoning related to the problem posed.
  • Some participants propose that a circle could be considered a "1 dimensional surface" within the framework of "n dimensional surfaces."
  • Others question the relevance of a circle to the problem, suggesting that a parabola is a more appropriate figure that meets the conditions of being equidistant from a point and a line.
  • A participant clarifies the mathematical formulation of the problem, emphasizing the need to find points in three-dimensional space that satisfy the distance condition.
  • One participant expresses initial confidence in the circle being the solution but later acknowledges a different outcome related to a circular paraboloid.
Participants do not reach a consensus on whether a circle qualifies as a surface in this context. Multiple competing views are presented regarding the definition of a surface and the appropriate geometric figure for the problem.
The discussion highlights varying definitions of surfaces and the specific conditions of the mathematical problem, which remain unresolved. There is ambiguity regarding the assumptions underlying the definitions and the problem's requirements.
HAL10000
The question asks to look for a surface and a circle is the only function which meets the conditions. Is this still considered a surface?
If it is really true that only the circle meets the conditions then there's hardly anything to talk about here, but the
interesting thing is, imo: what exactly is your definition of surface?
No, a circle is a surface if and only if you are talking about the "general" "n dimensional surface" in which case you can think of a circle as a "1 dimensional surface". Of course, it would help a lot if you told what the "question" really is!
The question asked for a surface which is equidistant from all points p(x,y,z) to the point (0,0,1) and the plane through z=-1
I don't see that a circle figures into this problem at all. In the plane, a parabola is equidistant from a given fixed point and a given line. In other words, at each point P on the parabola, the distance from P to the fixed point is equal to the distance from P to the line.
Although a circle is a perfectly good 1 dimensional surface, it's not the solution to your problem.
I believe your problem is asking for this:
Find all points ##(x,y,z)\in \mathbb{R}^3## such that
$$\mathrm{distance}\left( (x,y,z) , (0,0,1) \right) = \mathrm{distance}\left( (x,y,z) , \mathrm{plane} \right) $$
I have written it this way as to not give away the answer.
Cool :) and I was so certain about that circle lol. Thanks a lot. I get a circular prabolloid with a and b = 2.
  • · Replies 33 ·
