Register to reply
Angular Acceleration Using Work and Energy Principals
Share this thread:
mm391
#1
May23-12, 08:56 AM
P: 63
The chain of a workshop crane is 50 m long and has a mass of 3 kg/m. It is partially wound on a drum and the effective radius from the axis of the drum to the chain centre line is 0.2 m. The drum itself, including shaft and gear wheel has a mass of 100 kg and has a radius of gyration of 0.15 m. A steel block with a mass of 500 kg is to be lifted from a point 20 m below the level of the axis of the drum. If a torque of 1.3 kNm is applied to the drum, what will be the initial vertical acceleration of the steel block?
2. Relevant equations
P.E = mgh
K.E = 1/2mv^2
I = mK^2
Torque = radius * Force
Work Done = F*distance
F=mass* acceleration
3. The attempt at a solution
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
mm391
#2
May24-12, 07:42 AM
P: 63
I have just found out it is meant to be using angular and linear momentum but I a m still stuck:
Sum of moments = angular momentum
Momentum = Inertia*angular velocity + mass*velocity*radius
LawrenceC
#3
May25-12, 12:23 PM
P: 1,195
Sum of moments is not angular momentum. Sum of moments is the moment of inertia multiplied by the angular acceleration.
mm391
#4
May25-12, 03:34 PM
P: 63
I solved it many thanks for your help.
Register to reply
Related Discussions
Angular acceleration and velocities - verification of work Introductory Physics Homework 1
Work and Energy - angular force with friction Introductory Physics Homework 0
Can you check my work for this problem dealing with Angular Acceleration and Rotation Introductory Physics Homework 3
Work and Energy Theorem- change in acceleration Introductory Physics Homework 7
Rotational motion -angular energy+angular acceleration Introductory Physics Homework 4
