How can I express the coordinates of a pentagram in the complex plane using Phi?
  • Context: Graduate
  • Thread starter Thread starter arcnets
    Coordinates
The discussion revolves around expressing the coordinates of a pentagram in the complex plane using the Golden Ratio, Phi. Participants explore mathematical representations, including roots and exponentials, and the challenges of simplifying these expressions.
  • One participant proposes that the corners of a pentagram can be expressed as x = exp(2n*pi*i/5) for a radius of 1.
  • Another participant attempts to express the coordinates in terms of roots rather than exponentials, resulting in a complex expression involving the Golden Ratio.
  • Some participants suggest that certain coordinates will inherently involve nested square roots, particularly when using Phi.
  • There is a discussion about whether it is possible to simplify expressions involving square roots of Phi, with some participants expressing skepticism about achieving a fully linear representation.
  • One participant suggests squaring expressions to find coefficients, but notes that this leads to square roots within square roots.
Participants generally agree that the expressions for the coordinates will involve square roots, particularly when using the Golden Ratio. However, there is no consensus on whether it is possible to eliminate these square roots entirely or simplify them further.
Limitations include unresolved mathematical steps regarding the simplification of square roots involving Phi and the potential complexity of the expressions derived from the pentagram's geometry.
arcnets
Hi,
I tried to find out how to plot a pentagram in the complex plane. Let the radius of the pentagram be 1, then all the corners of the pentagram satisfy the equation
x^5 = 1 (where x is a complex number).
The answer is, of course, x = exp (2n*pi*i/5).
But I wanted to express that in roots, not in exponentials.
I could not find anything on the Web, so I tried it myself.
It can be done, but the answer is not beautiful.
The prime root is:
x = a + i*a / sqrt(1-2/sqrt(5)),
where a = [ (9-4*sqrt(5)) / (16*sqrt(5)-16) ]^(1/5).
Next, I tried to express this in terms of the "Golden Ratio" Phi. Because I knew that Phi appears in the pentagram a lot.
Since
Phi^2 = 1*Phi + 1
Phi^3 = 2*Phi + 1
Phi^4 = 3*Phi + 2
Phi^5 = 5*Phi + 3
... and so on (that's the Fibonacci series twice),
we get
x = (Phi - 1)/2 + sqrt(Phi + 2)*i/2
and also
x^2 = -Phi/2 + sqrt(-Phi + 3)*i/2.
(x^3 and x^4 are obviously symmetrical wrt. the real axis)
That looks better.
But not perfect. I tried to get rid of the square root in the imaginary part, because I wanted everything to be linear in Phi. But no success.
Any help?
I'm pretty sure that one coordinate will require a square root nested inside a square root.
Well,they do.Using
[tex]\varphi=:\frac{1+\sqrt{5}}{2}[/tex]
,u see that sqrt of \phi implies sqrt from an sqrt...
Daniel.
Right -- I was suggesting that he's stuck with something involving the square root of phi.
IMHO, it's better to explicitly write out what it is, rather than suppressing the square root of 5 into phi.
Thanks Hurkyl.
Of course, in some cases, a root containing Phi can be removed. For instance,
sqrt(Phi + 1) = phi
sqrt(3*Phi + 2) = phi + 1,
etc.
Do you think it's impossible for
sqrt(Phi + 2) = ?
sqrt(-Phi + 3) = ?
Suppose it can be written as a * phi + b. Now square both sides and try to solve for a and b...
Yes. It works, but the coefficients have a square root inside a square root.
  • · Replies 26 ·
  • · Replies 33 ·
