| New Reply |
What is the probability of this? |
Share Thread | Thread Tools |
| May25-12, 11:27 AM | #18 |
What is the probability of this?In the new stated problem, again, every ball has the same probability! so you already know your new solution won't have any p either....
| May25-12, 07:09 PM | #19 |
| May25-12, 07:13 PM | #20 |
I think you've just suffered enough
| May25-12, 07:37 PM | #21 |
Recognitions:
[itex] {{K}\choose{k}}^{-M+1}[/itex] |
| May26-12, 04:49 AM | #22 |
But even if you transform the problem and turn "each person pulls k" into "each person pulls the same number" being those numbers equally likely, and the question "What is probability that all persons pull the same k balls?" into "What is probability that all persons pull the same balls?" Then the answer would be: [tex]\frac{1}{K+1}\sum_{k=0}^K {{K}\choose{k}}^{-M}[/tex] |
| May26-12, 05:50 AM | #23 |
Recognitions:
Let's take a simple example. K=2, k=1, M=2.
Each takes one ball and replaces it. What's the probability they take the same ball? You say [itex] {{K}\choose{k}}^{-M}[/itex] = 2-2 = 1/4 I say [itex] {{K}\choose{k}}^{-M+1}[/itex] = 2-1 = 1/2 Think about it. |
| May26-12, 07:05 AM | #24 |
| May26-12, 05:04 PM | #25 |
| May26-12, 05:23 PM | #26 |
| May26-12, 05:39 PM | #27 |
There are M people and K distinct balls. Each of those M people will pick a number k at random between one and K inclusive and then pick k balls at random. An reliable observer will record which balls they picked. Then the selected balls are put back for the next person. After all M of these people have done this the reliable observer informs us that none of the M people picked the same number k of balls to select. Someone gives us an integer m. We want to give them the odds that the intersection of the ball picks contains exactly m balls. Is this a correct statement of the problem??? |
| May26-12, 05:59 PM | #28 |
I hope it is more clear now. Thanks |
| May26-12, 07:39 PM | #29 |
If there are M=2 people and K=5 distinct balls and there is a very high probability of 4 or 5 balls getting picked and none at all of 1 or 2 balls, then it is a very different situation than if there is no probability of 4 or 5 balls being picked and a high probability ofr 1 or 2 balls. If I understand your question, there is not enough information to answer it. |
| May26-12, 07:55 PM | #30 |
| May26-12, 08:01 PM | #31 |
Recognitions:
ClifDavis is right, of course: you need to specify the probability distribution for k.
But it sounds from an earlier post that k is supposed to have a uniform distribution from 1 to K. If so, it sounds like a very nasty problem. |
| May26-12, 08:02 PM | #32 |
Recognitions:
| May26-12, 08:11 PM | #33 |
| May26-12, 08:19 PM | #34 |
Recognitions:
In that case I select a binomial distribution. This means I can rephrase it as "each ball is chosen independently with probability p".
The probability that a given ball is selected by all M is then pM. The number of balls selected by all is binomial with parameter pM. However, I have violated the statement that k must be 1 to K. I've made it 0 to K. Is that alright? |
| New Reply |
| Thread Tools | |
Similar Threads for: What is the probability of this?
| Conditional probability - Probability of spotting a downed airplane (really basic) | Set Theory, Logic, Probability, Statistics | 3 | ||
| a simple probability problem involving the law of total probability | Calculus & Beyond Homework | 1 | ||
| Probability question; Conditional probability and poisson distribution | Precalculus Mathematics Homework | 1 | ||
| HELP geometric probability: area of a square and conditional probability | Precalculus Mathematics Homework | 4 | ||
