Register to reply
Quantum tunneling and radioactive decay.
by bayan
Tags: decay, quantum, radioactive, tunneling
Share this thread:
bayan
#1
May25-12, 03:21 AM
P: 202
The edge of a nucleus can be roughly modeled as a square potential barrier. An alpha particle in an unstable nucleus can be modeled as a particle with a specific energy, bouncing back and forth between these square potential barrier.
Consider a nucleus of radius r and an alpha particle with kinetic energy E (i.e., let the potential energy within the nucleus be zero) and mass m.
Assuming that the alpha particle moves along a diameter of the nucleus and that it moves at low enough speed that relativistic effects are negligible, what is the time tau between successive encounters between each edge of the nucleus and the alpha particle?
Express your answer in terms of [itex]K_{e}[/itex], [itex]r[/itex], and [itex]m[/itex].
2. Relevant equations
[itex]K_{e}=mv^{2}[/itex]
3. The attempt at a solution
[itex]v^{2}=\frac{(2r)^{2}}{t^{2}}[/itex]
[itex]\frac{K_{e}}{m}=\frac{(2r)^{2}}{t^2}[/itex]
[itex]\sqrt{\frac{K_{e}}{m}}=\frac{2r}{t}[/itex]
[itex]2r\sqrt{\frac{m}{K_{e}}}={t}[/itex]
Have I used the right approach to this problem? and have I got the correct answer?
Thanks in advance
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
bayan
#2
May25-12, 07:55 PM
P: 202
Seems like the answer does not need the 2 in my answer, which means I have made a mistake in my approach or calculation. Anyone able to help out?
Thanks.
Curious3141
#3
May25-12, 08:50 PM
HW Helper
Curious3141's Avatar
P: 2,943
I'm not really sure about your approach, but there is a factor of half missing in your KE equation:
[tex]K_e = \frac{1}{2}mv^2[/tex]
Does that help?
bayan
#4
May26-12, 01:07 AM
P: 202
Quote Quote by Curious3141 View Post
Does that help?
I should hope so, lol
Register to reply
Related Discussions
Quantum Tunneling in a Scanning Tunneling Microscope Quantum Physics 5
Quantum random number generator with radioactive decay Quantum Physics 1
Nuclear Chemistry: Kinetics of Radioactive Decay and Radioactive Dating Biology, Chemistry & Other Homework 1
Decay of Alpha Particle Through Quantum Tunneling Advanced Physics Homework 1
Radioactive decay equilibrium when decay constants are equal Biology, Chemistry & Other Homework 2
