Thread Closed
HELP! relationship between rate of flow of water and height of water column
Share Thread
Jan23-05, 07:38 PM   #1
Exclamation
Purpose : to determine experimentally the relationship between the rate of flow of water through a narrow opening and the height of the water column.
any ideas in how i could do this experiment and what kind of data to use etc. and how this can conclude to a design in an hydro electric dam.
experiment is used with a 50 mL burette (tube with narrow opening) , stop watch, ruler, and beakers.
thanks :D
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jan23-05, 07:59 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by byronsakic19
Ask yourself the following questions:
1. what do I need to produce a column of water? Will it be big enough to give me a measureable volume of water flowing out the opening without changing the height significantly?
2. how do I measure the volume of water that escapes?
3. How do I measure the time it takes to escape so I can determine the volume/unit time?
4. How do I measure the area of the opening? How do I calculate the flow rate from that data and the area of the opening?
If you think about all these things carefully, you will be on the road to a successful experiment.
AM
Thread Closed
Similar discussions for: HELP! relationship between rate of flow of water and height of water column
Thread Forum Replies
Water bath system - flow rate problems General Engineering 1
Tap water flow and water diameter at end of it (Bernoulli eqzn...) Introductory Physics Homework 4
Rate of flow - height of water problem Differential Equations 4
Vertical flow rate of water stream under gravitation General Physics 7
Confused with flow rate of water Classical Physics 3
