Trying to explain how a Relaxation Oscillator UJT circuit works
The discussion focuses on the operation of a Relaxation Oscillator circuit utilizing a Uni-Junction Transistor (UJT). A UJT is defined as a transistor with a single emitter and two bases, characterized by its breakthrough voltage (Vp) and the relation coefficient η, calculated as Rb1/(Rb1+Rb2). The circuit generates pulses by charging a capacitor until it reaches Vp, at which point the UJT conducts, allowing current to flow from the emitter through base B1, and subsequently returning to cutoff when the voltage drops to a minimal value (Uv).
  • Understanding of Uni-Junction Transistor (UJT) functionality
  • Knowledge of circuit components such as capacitors and resistors
  • Familiarity with voltage concepts, specifically breakthrough voltage (Vp)
  • Basic grasp of electrical circuit analysis
  • Study the characteristics and applications of Uni-Junction Transistors (UJTs)
  • Explore the design and analysis of Relaxation Oscillator circuits
  • Learn about pulse generation techniques in electronic circuits
  • Investigate the impact of resistance values on UJT operation and circuit behavior
Electronics students, hobbyists, and engineers interested in understanding UJT circuits and pulse generation techniques in electronic design.
Femme_physics
http://img689.imageshack.us/img689/7084/ujte.jpg This is a Relaxation Oscillator circuit with UJT. I need to A) Explain what is UJT, explain its relation ratio of η for the UJT, and explain what Vp is. And in B) Explain how does the circuit work, and what is the output (or turnout) of the circuit
Trying to use my own wordsUJT is a uni-junction transistor that has a single emitter and two bases. As long as the voltage in the emitter is smaller than the breakthrough voltage (Vp) , the UJT acts as disconnection.
When the voltage in the emitter gets to the same voltage as Vp, the resistance at the base is broken through B1, and when the voltage in the emitter drops to a minimal value Uv, UJT is back to cutoff.
relation coeffcient - η = Rb1/(Rb1+Rb2)
Vp is "peak voltage" or "breakout" voltage. When the voltage in the emitter arrives to Vp then the UJT opens up (broken though).
(Hope I didn't lose anyone by now!)
B) This circuit generates pulses. Its made out of UJT and a capacitor. The capacitor is loaded from the source and when it reaches Vp, the UJT opens up and current flows from the Emitter through B1.
Well, I haven't learned about UJT's before, but after googling it I'm drawing the conclusion that you summed it up nicely. :)
Actually, I like your explanation better than some others on the internet.
I'm turning into an electronics expert thanks to you!
Much appreciated :)
