New Reply
how rear axle turns? (in cars)
Share Thread Thread Tools
May27-12, 02:15 AM   #1
in cars front axle turns by diffrential but how rear axle turns it is possible wite pure rolling?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
May27-12, 02:38 AM   #2
Recognitions:
Gold Membership Gold Member
Quote by persia7 View Post
Welcome to PF, Persia7.
You sort of lost me with that question. The rear wheels are turned by a differential, unless you have a front-wheel-drive vehicle. The front ones just free-wheel, unless the brakes are applied. The opposite is true for a FWD thing.
May27-12, 03:30 AM   #3
when two wheels are rigid to axle ,how axle can turn without slip?
May27-12, 03:37 AM   #4
Recognitions:
It can't. This is why a differential arrangement is used, so both driven wheels can transmit power at different speeds.
Check out the 'how stuff works' article on the same, or build one out of Lego to understand better.
http://www.howstuffworks.com/differential.htm
May27-12, 03:44 AM   #5
in front wheel drive cars ,rear axle havent diffrrential , how it can turn?
May27-12, 03:58 AM   #6
cart havent diffrential but how it can turn in corner?
May27-12, 04:03 AM   #7
Recognitions:
welcome persia
on front wheel drive cars, the rear wheels are simply wheels on bearings abd are free to rotate independatly of the drive wheels. They are just along for the ride..savvy?
May27-12, 04:07 AM   #8
if front axle need diffrential to turn (in corner) then why rear wheels doesnt?
May27-12, 04:52 AM   #9
Recognitions:
the front wheels must transmit power to the road..since rear wheels are not connected to engine..no differential is required..only independant bearings
May27-12, 07:05 AM   #10
please explain what force and how cause rear axle turns in corners ??
May27-12, 11:04 AM   #11
Recognitions:
This is like talking to a rock, but I'm going to assume that it's an "English as 2nd language" problem.
Okay... get yourself a Hot Wheels or Matchbook toy car and check out how the wheels turn. Now imagine a differential on one end of it. That's what we're talking about. Ignore the fact that they don't have steering mechanisms; it's irrelevant here.
May27-12, 12:06 PM   #12
Front wheel drive vehicles have a differential as part of the transaxle. The rear wheels on a front wheel drive vehicle are not locked the same axle. Each one can free-wheel independent of the other.
Rear wheel drive vehicles have a differential in the center of the rear axle. The front wheels on a rear wheel drive vehicle are obviously not locked to the same axle. If they were, steering would be impossible. -
There, I tried.
New Reply
Thread Tools
Similar Threads for: how rear axle turns? (in cars)
Thread Forum Replies
Wheel pivoted about a frictionless axle - moment of inertia, force of axle Introductory Physics Homework 0
What is a rear shock? Introductory Physics Homework 2
+ or X Rear fins?? Aerospace Engineering 5
Forget electric cars, what about try to design photonic cars? General Discussion 17
bad rear axle shocks very common? General Discussion 7
