Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > General Engineering
Reply
image Statically Indeterminate Problem Share It Thread Tools Search this Thread image
Old Jan23-05, 11:53 PM                  #1
wisper
wisper is Offline:
Before you start going through equations and trying to solve this I just need a simple question answered about this problem.
1) Is it correct for me to assume that the pressure on both walls is equal?
If so, I think the normal stress of the aluminum and steel bars are equal.
Problem:
A circular bar consist of 3in diameter aluminum alloy with Young’s modulus, E = 10,600 ksi, poisson ratio, ν = 0.33, and temperature coefficient, α = 12.5 * 10-6 /°F and 4in diameter steel with Young’s modulus, E = 30,000 ksi, poisson ratio, ν = 0.3, and temperature coefficient, α = 6.6 * 10-6 /°F separated by a rigid piece as shown. The bar is fixed between two rigid end supports and is considered unstressed at 0°F. Determine (a) the normal stress in both the aluminum bar and the steel bar, and (b) the change in diameter of the aluminum and steel bar.
Diagram of Problem
Old Jan24-05, 12:50 PM                  #2
FredGarvin
FredGarvin's Avatar
Engineer Guru 2008
FredGarvin is Offline:
Recognitions:
PF Contributor PF Contributor
Since the stresses are inversely proportional to area and Young's, the two members will not have the same stresses.
Old Jan24-05, 07:00 PM                  #3
wisper
wisper is Offline:
Thank you.
Old Jan25-05, 11:31 AM                  #4
enigma
enigma's Avatar
enigma is Offline:
Recognitions:
Retired Staff Retired Staff
The force is the same through the entire section, but not the pressure.
image image
Reply
Thread Tools
Similar Threads for: Statically Indeterminate Problem
Thread Thread Starter Forum Replies Last Post
statically indeterminant problem oakley45 General Engineering 3 Nov30-07 11:03 PM
Is this indeterminate? Feldoh Calculus & Beyond 0 Sep9-07 04:55 PM
An introduction to the analysis of statically indeterminate systems radou Engineering, Comp Sci, & Technology Learning Materials 4 Dec19-06 11:10 AM
Statically Indeterminate Stepped Bar Problem noboost4you Engineering, Comp Sci, & Technology 5 Dec2-06 11:36 PM
Indeterminate lomantak Calculus & Analysis 3 Oct9-06 04:09 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
