| New Reply |
Transformation Vs. Physical Law |
Share Thread | Thread Tools |
| May29-12, 05:22 PM | #52 |
Transformation Vs. Physical LawThe answer to the OP is that the physical law describing the half-life of a sub-atomic particle moving in the x, y, and z directions by the amounts dx, dy, dz in the time dt is purely a function of the quantity sqrt[dt^2 - dx^2 - dy^2 - dz^2] where x,y,z,t are any single system of inertial coordinates. No transformation is involved. (But of course x,y,z,t do have to be coordinates in terms of which the laws of mechanics hold good.) In fact, we find that every physical process and phenomenon (not just the half-lives of sub-atomic particles) has this same form, in the sense that the physical laws don't depend on the absolute values of x,y,z,t, nor even on the absolute values of dx,dy,dz,dt or their ratios, but only on the quantity dt^2 - dx^2 - dy^2 - dz^2. The fact that these physical laws work equally well in terms of any standard system of inertial spacetime coordinates implies that this quadratic quantity is the same in all of them. After noticing this, and then seeing it confirmed over and over again for all known physical laws, we begin to expect it to be true, even when trying to formulate the laws governing previously unknown phenomena. This property, called Lorentz invariance, is not itself a physical law, it is an attribute of all known physical laws. It's useful to know about Lorentz invariance because it enables us to compute things very easily by taking a short cut. If we already know that a certain physical law (such as the law for the half-life of a particle) is Lorentz invariant, we know that we can compute things in any convenient system of standard inertial coordinates, and then very simply express the results in terms of any other system of coordinates using the Lorentz transformation (which happens to be the transformation that preserves that quadratic quantity appearing in the physical laws). But this is just a computational shortcut, used by people who know what they're doing. If it confuses the OP, he can just go ahead and do things the more laborious (and less insightful) way. |
| May29-12, 05:27 PM | #53 |
Do you doubt the validity of time dilation as a function of relative motion as it is described in the Lorentz math?? If you don't then I don't understand why you think there is a problem. Is it the semantic question of whether time dilation is called a law or a transformation? You seemed to agree that it could be both so I am confused as to your point here. |
| May29-12, 05:42 PM | #54 |
Regarding the invariant interval, I understood it was a direct derivation from the Lorentz math. Is this incorrect? |
| May29-12, 05:55 PM | #55 |
| May29-12, 06:16 PM | #56 |
Mentor
I find a certain appeal to starting with the interval. After all, to me, the notion of distance seems more basic than the notion of coordinates. |
| May29-12, 06:22 PM | #57 |
But beyond that, I have thought about how we can demonstrate that the two Doppler factors (coming and going at the same speed) are reciprocals and I found the answer in Hermann Bondi's book, Relativity and Common Sense, pages 77 to 80. So we can figure it out either by experiment or by analysis. |
| May29-12, 06:33 PM | #58 |
There are many ways to derive the equation but that is irrelevant to what I am saying. And yes, the classical Doppler shift equation won't work because it is not relativistic. |
| May29-12, 06:47 PM | #59 |
could you point me to the experimental tests revealing length contraction? I have looked without coming across anything. Thanks |
| May29-12, 07:08 PM | #60 |
But to suggest you can apply this principle to the twins question to explain the difference in final age, without invoking the gamma factor inherent in the relativistic Doppler equation, is a different story. Wouldn't you agree? |
| May29-12, 08:24 PM | #61 |
| May29-12, 09:43 PM | #62 |
Moreover, the assertion that every pair of inertial observers will each see the (presumed) standard frequency shifted by reciprocal factors when approaching and receding is tantamount to the assertion of not only source independence, but also directional independence and frame independence, meaning we are asserting the complete invariance of light speed in terms of any and every system of standard inertial coordinates. Naturally we aren't required to explicitly construct such coordinates, but they are implicit in those premises. If two twins are directly approaching a central transmitter from opposite directions (all unaccelerated) and they see equal frequencies, we must say they have equal speeds relative to the rest frame coordinates of the transmitter. They pass the transmitter simultaneously and again see equal frequencies and therefore have equal speeds, so they implicitly define a system of space and time coordinates based on light synchronization. (We say they are at equal distances when they have received equal numbers of pulses.) |
| May29-12, 11:33 PM | #63 |
This is the center point of the debate, in special relativity it is the Lorentz transformations which are used to explain the differential ageing. But instead we should have a physical law explaining these differences, which then can be validly transformed for any other inertial observing frame using Lorentz transformation. |
| May29-12, 11:38 PM | #64 |
Reciprocity of Doppler by itself ,without the gamma factor , does not imply aging differential. So you are assuming that factor behind the scene , applying that to Speedo's hypothetical observations and then asserting that Speedo, if he were mathematically inclined, could derive the Lorentz transformation directly from these observations. Are you really claiming that the gamma is not involved or necessary to the explanation? |
| May29-12, 11:43 PM | #65 |
I mean, its alright to disagree with me or anyone for that matter, but rejecting everything that I post is gravely unscientific. |
| May29-12, 11:48 PM | #66 |
Recognitions:
| May29-12, 11:54 PM | #67 |
| May30-12, 12:11 AM | #68 |
So GR predicts certain cases of time dilation but no particular explanation of the mechanism. The Lorentz math predicts certain other cases of time dilation also with no explanation of mechanism. If you want, you can say GR is a law and the Lorentz math a transform but in this case that is a distinction without a difference. A semantic quibble not worth pursuing. The function and utility are exactly the same. I would say that the Lorentz math was fundamentally a physical law and only secondarily a transformation but that is also a semantic question not worth any effort. So i think you might be better served directing your intelligence towards more interesting questions and subjects, just mHO |
| New Reply |
| Thread Tools | |
Similar Threads for: Transformation Vs. Physical Law
| Linear Fractional Transformation (Mobius Transformation) from circle to line | Calculus & Beyond Homework | 10 | ||
| Particle/wave duality: physical reality? Or really physical crackpottery? | General Physics | 4 | ||
| physical interpretation of unitary transformation | Quantum Physics | 3 | ||
| What is the Physical meaning of Bogoliubov transformation | Atomic, Solid State, Comp. Physics | 22 | ||
| How does a physical brain create non-physical things? | Medical Sciences | 8 | ||
