| New Reply |
Transformation Vs. Physical Law |
Share Thread |
| May30-12, 12:22 AM | #69 |
Recognitions:
Transformation Vs. Physical LawEach twin's age depends only on the path that twin takes through space-time. So I compute the age of twin one at the reunion by looking at twin one's path through space-time; twin two and the relative velocity don't enter into this computation at all. Then I compute the age of twin two at the reunion by looking at twin two's path through space-time; twin one and the relative velocity don't enter into this calculation at all. And now that I know their ages at the moment of reunion... I know what the difference in their ages is. |
| May30-12, 12:39 AM | #70 |
| May30-12, 12:49 AM | #71 |
Recognitions:
If it were, I wouldn't be able to calculate the aging of anyone who didn't have a twin... Surely you aren't suggesting that an only child suspended in the midst of empty space (so that's there's no relative velocity because there's nothing to be relative to) won't age, or that I can't calculate the aging? All we need to do is to look at his wristwatch. But if I can calculate the aging of the isolated only child without considering his velocity relative to a twin that he doesn't even have.... Clearly I can do the same for either twin, just by ignoring the other twin and the relative velocity between them. |
| May30-12, 12:50 AM | #72 |
That is, how many events(differential age of the twins) would take place is concluded by using the gamma factor of a transformation. Now, it is this use of the gamma factor to produce difference in the ages of the Twins, make it necessary to have real Length contraction phenomena, to which we don't have any experimental support. Instead, it is the Time Dilation of unstable particles(using LT) which is directly challenged by the recent new findings, of dependence of the nuclear decay rates on the Earth-Sun distance, which includes beta decaying particles(Muons). |
| May30-12, 12:53 AM | #73 |
| May30-12, 12:54 AM | #74 |
Recognitions:
| May30-12, 01:33 AM | #75 |
You keep moving the argument around. Do you still think there is a paradox buried in all this ? |
| May30-12, 01:43 AM | #76 |
For example, with Dopplers of 2 and 1/2, the average of them is 1.25 which means that as the traveling twin kept his eye on the stationary twin's clock through the entire trip, he first saw it ticking at 1/2 the rate of his own, then for the return trip, he watched it tick twice as fast as his own. You can confirm that at a relative speed of 0.6c, the relativistic Doppler factors are 2 and 1/2 and that gamma equals 1.25. Another example, with Dopplers of 3 and 1/3, the average is 5/3 or 1.667, and this occurs with a relative speed of 0.8c which produces a gamma of 1.667. The point is that we don't need to know the value of the speed in order to calculate the age difference which happens to be equal to gamma. |
| May30-12, 01:50 AM | #77 |
| May30-12, 01:53 AM | #78 |
| May30-12, 02:07 AM | #79 |
Suppose I concede the point that the calculation could be done in one of the twins frames - what conclusion would you draw from that ? Are you still saying that using a transformation to change frames invalidates the laws of dynamics ? |
| May30-12, 02:12 AM | #80 |
| May30-12, 02:24 AM | #81 |
Please, don't say that, they do so because their worldlines are different, but there is no relation to the relative velocity. Because the concept of the world-lines is abstract, and even difference in the world-lines of the two objects in a frame, is known as Lorentz transformation, whereas, we are talking about the difference in age which is invariant. |
| May30-12, 02:28 AM | #82 |
universal_101, how is the comparison of proper times, as it is done in the twins paradox relevant to the expression of physcal laws in one frame or another ?
In the case of the muon decay it has been pointed out that we can write the 'law' (equations ) governing detector counts in any frame with no inconsistency ? [edit] I just saw this |
| May30-12, 02:34 AM | #83 |
SO when you say one twin sees the time on the other twins clock you are calculating what he sees using the transformed version of classical Doppler. yes? I think Gamma cannot be derived simply from reciprocity of classical Doppler. Do you think otherwise? Because that is what you seem to be saying. |
| May30-12, 02:42 AM | #84 |
| May30-12, 02:56 AM | #85 |
So, you cannot refute the notion of different rates, since, experimental proof is needed to claim otherwise. |
| New Reply |
Similar discussions for: Transformation Vs. Physical Law
| Linear Fractional Transformation (Mobius Transformation) from circle to line | Calculus & Beyond Homework | 10 | ||
| Particle/wave duality: physical reality? Or really physical crackpottery? | General Physics | 4 | ||
| physical interpretation of unitary transformation | Quantum Physics | 3 | ||
| What is the Physical meaning of Bogoliubov transformation | Atomic, Solid State, Comp. Physics | 22 | ||
| How does a physical brain create non-physical things? | Medical Sciences | 8 | ||
