Why is Random Error Higher than Literature Error?
The discussion centers on the unexpected outcome where the random error percentage (12.1%) exceeds the literature error percentage (7.45%) in an experiment determining the atomic radius (Ar) of lithium (Li). The calculated value of 7.5 is compared to the literature value of 6.941, raising questions about the implications of this discrepancy. It is established that as long as the calculated value's error range overlaps with the true value, the results are considered acceptable, emphasizing the importance of understanding error definitions in experimental contexts.
  • Understanding of atomic radius calculations
  • Familiarity with error analysis in experimental physics
  • Knowledge of statistical error definitions
  • Experience with comparing experimental results to literature values
  • Research statistical methods for calculating random errors in experiments
  • Study the principles of error propagation in physical measurements
  • Learn about the significance of literature values in scientific experiments
  • Explore techniques for improving accuracy in atomic radius measurements
Students in physics or chemistry courses, researchers conducting experimental analysis, and educators teaching concepts of error analysis and measurement accuracy.
huey910
In an experiment to determine the Ar of Li, the % error due to random errors was calculated to be 12.1%. However, the literature value is 6.941 and my calculated value is 7.5 which means my % error s 7.45.
Usually, the error due to the literature value is greater than the % error due to random errors, but now it is the reverse - what does this mean?
I'm not sure how you arrived at your error of 7.45%, but you should keep in mind that the error defines a region (a range of values) within which the 'true' value should lie. So long as your calculated value's error range overlaps the 'true' value, then all is well. If your calculated value happens to be close to the literature value, all the better, after all you were aiming for it!
  • · Replies 17 ·
9K
