How does a cantilever have a torsional mode in micro size?
The discussion centers on the torsional resonant modes of microcantilevers, specifically how these modes arise from material properties and force application. A participant explains that torsional modes can be induced by either asymmetric forces or symmetric forces acting on an asymmetric crystalline structure. The analogy of a ruler is used to illustrate how applying force off-center can cause twisting, highlighting the importance of material composition in microcantilever behavior. Additionally, it is noted that microcantilevers exhibit four distinct oscillating modes in response to resonance frequency.
  • Understanding of microcantilever mechanics
  • Familiarity with resonant frequency concepts
  • Knowledge of material properties and their effects on structural behavior
  • Basic principles of torsional dynamics
  • Research microcantilever design principles and applications
  • Study the effects of material asymmetry on torsional modes
  • Explore resonant frequency analysis techniques for microstructures
  • Learn about the mechanical properties of different materials used in microcantilevers
Engineers, researchers, and students in the fields of materials science, mechanical engineering, and nanotechnology who are interested in the dynamics and applications of microcantilevers.
Tah
Hi,
I've already made a question and recently received a reply.
My question is how does a microcantilever have a torsional resonant mode.
We generally study a longitudinal mode, not so much considering the torsional mode.
The man who replied to my question said
"It's because of the material it is made from. Torsional modes can be induced in two ways. Firstly an asymmetric force or secondly a symmetric force on an crystalline structure which is asymmetric. "
But I still have a difficulty in understanding that meaning.
Can anyone describe it much easier?
Take a ruler and hold it on your desk so that it forms a cantilever over the edge.
Now press down at the end but in the middle of the ruler.
The ruler deflects in bending as expected.
You will find, however, that if you push down on one side or the other at the end the ruler also twists.
Now imagine your ruler is softer one side than the other (perhaps it has the steel insert one side).
This time distribute your pressure across the end of the cantilver instead of at a point.
Again your ruler twists a bit as well as deflecting, this time because of the different structural properties along each side.
Thanks Studiot
Your explanation is very easy to understand.
Could you explain a little bit more about your example with resonant frequency?
Microcantilever has four different oscillating modes in response to the resonance frequency.
Thank you.
  • · Replies 152 ·
12K
