| New Reply |
WHat is the uncertainty in a metre rule?? |
Share Thread | Thread Tools |
| May31-12, 04:33 PM | #35 |
| May31-12, 04:38 PM | #36 |
Recognitions:
As an example for 0.2 standard deviation, this means that 0.3 is usually (~70%) read somewhere between 0.1 and 0.5. It is sufficient to see that 0.3 is smaller than 0.5, but not close to 0, to do this. 0.5 should usually be read somewhere between 0.3 and 0.7 - which is everything not close to a mark on the scale. If you want to give some "upper bound" for the error, you should use larger values, of course. But an upper bound is not always well-defined (apart from digital displays). And if you want to use the marks on the scale, you should format your numbers like [itex]0.3^{+0.7}_{-0.3}mm[/itex] |
| May31-12, 04:38 PM | #37 |
Yes indeed using ± notation.
But if you are limited to scale divisions you cannot report half divisions, your statement has to be 2 or 3, not 2.5 ± 0.5. That implies you have to report 0,1,2,3,4 etc. So a report that the thickness is 2 implies that it is between 1 and 3 ie 2 ±1 Which is what I said. Incidentally you need to revise your statement on end standards. |
| May31-12, 04:51 PM | #38 |
[tex] \sigma_{U} = \frac{b - a}{2 \sqrt{3}} [/tex] Notice that [itex]2 \sqrt{3} \approx 3.5[/tex] As for end standards, we are not doing calibration of etalons. We are measuring the length of an object. Thus, we are free to slide the scale so that the left end coincides exactly with one of the ruler's divisions. Then, there is uncertainty in reading off only the right end. There might be systematic errors due to the bad calibration of the rulers divisions, but that's another point. |
| May31-12, 05:01 PM | #39 |
And BTW why mention etalons? However I have not seen one as long as 1 metre. |
| May31-12, 05:06 PM | #40 |
Last few comments are missing the point and rely on unsubstantiated assumptions.
Trying to see something between divisions which is not there! Assuming that there is some uniform scale within the division Assuming there is no distortion. The example of digital instruments should serve as a clue.... There is no way to 'eyeball' how close the last digit is to the one above or the one below. +/-1 max is a safe, sensible, objective bet. |
| May31-12, 05:07 PM | #41 |
| May31-12, 05:08 PM | #42 |
I have used draughts mans scales ......I have also used verniers
| May31-12, 05:09 PM | #43 |
Recognitions:
truesearch, error is not the absolute maximum or minimum you can be wrong by. It's the average error. So it behaves like a random walk. For a random walk of N steps of distance L each, the average distance you travel is L*Sqrt(N). So average error behaves like RMS.
In practice, the actual value of how much you are off by will be normally distributed. The quoted error is the standard deviation of that distribution. |
| May31-12, 05:14 PM | #44 |
As a matter of inerest how do you guarantee that the aligned 'zero' stays put while you read the other end? I know how the navy does it for a traverse tape and how an engineering workshop does it for an engineering endstop rule and similarly how a drapers shop does it for a drapers endstop rule. Why do you think they do it this way with an end stop rather than your way? |
| May31-12, 05:16 PM | #45 |
| May31-12, 05:23 PM | #46 |
In fact, if the sources you allude to start giving comparable contributions, then it means your measuring scale is so precise that you do not get the same result as you repeat the measurement. In other words, you start getting statistical errors. |
| May31-12, 05:37 PM | #47 |
Dickfore all you are proving is that different people in different 'laboratories' use different techniques and thereby achieve (slightly) different results by going their own way.
The whole object of calibration and standardisation is so that anyone anywhere can achieve the same result under the same conditions. This involves standardisation of measurement technique as well as tools in order to remove 'operator bias'. Measurement against a common stop end is one such standard. If a laboratory develops its own special techniques it needs to report these as part of the results. I once worked in such a laboratory measuring the lengths of bricks, accurate to less than a 10thou using the lab's specially developed technique. But we never pretended it was 'standard' or that the method should be widely adopted. |
| May31-12, 05:45 PM | #48 |
Let us say that (by the method I described), I get a length measurement of 3.5±0.5 mm. Then, you come with your fancy equipment and get a result 3.329±0.007 mm (you had to repeat the experiment several times because you noticed that every time you get a different reading with your fine equipment. Then, you took the mean, and you found the standard deviation of the mean, and you took a 95% confidence interval for the mean.) Does that make my measurement "wrong"? |
| May31-12, 05:53 PM | #49 |
Mentor
I feel confident in assigning ±0.1 mm when using a metal scale with finely-engraved lines, in a way that eliminates or minimizes parallax error due to the thickness of the scale. It helps that I'm rather nearsighted so I can get my eye about 10 cm from the scale if I take off my eyeglasses. If I'm using a typical plastic ruler with relatively thick mm-lines, I might use ±0.2 mm. If I'm using a thick meter stick and can't lay it edgewise on the object being measured so that I have to sight across the thickness of the meter stick, I might use ±0.5 mm or even ±1.0 mm. |
| May31-12, 05:59 PM | #50 |
Not at all to do with statistics.
But everything to do with technique which contains inherent sources of error v technique which avoids these. When you place your test piece and ruler against the stop end you have a guaranteed square and reproducible 'zero'. When you estimate the alignment of two lines along a sight line that may or may not be square and hold the ruler and testpiece at some random (albeit small) angle to each other you have a recipe for variability of measurement. Notice I said 'sight line'. Two operators will align the pieces slightly differently by sight. They cannot do this with a stop end. Edit JTbell has just described the visual alignment issue to a T whilst I was posting. |
| May31-12, 06:00 PM | #51 |
| New Reply |
| Tags |
| metre rule, uncertainity |
| Thread Tools | |
Similar Threads for: WHat is the uncertainty in a metre rule??
| Free oscillations of a metre rule | Introductory Physics Homework | 0 | ||
| A metre scale - contradiction | Introductory Physics Homework | 2 | ||
| uncertainty rule | Quantum Physics | 7 | ||
| 100 metre leap | Introductory Physics Homework | 4 | ||
| Descartes' Second Rule vs. Uncertainty | General Discussion | 94 | ||
