Sign Convention For Momentum Operators
The discussion revolves around the sign convention used in momentum operators within quantum mechanics. Participants explore the implications of different sign choices on the canonical commutation relations and the representation of wave functions, particularly in relation to spatial translations and their generators.
  • Some participants question how to determine the appropriate sign when using the momentum operator, suggesting that it may relate to satisfying canonical commutation relations.
  • Others propose that the choice of sign could be connected to the representation of wave functions, specifically in the form of e^{i(kx-wt)}, and inquire whether using the complex conjugate of the wave function would necessitate a corresponding change in the momentum operator.
  • One participant expresses dissatisfaction with the sequence of ideas presented in lecture notes, suggesting that a better understanding can be gained from considering eigenstates of the momentum operator as outlined in Ballentine's textbook.
  • Another participant notes that the choice of sign in describing spatial translations is arbitrary, mentioning that the usual convention is to use the positive sign. They elaborate on how this affects the translation operator and its action on position eigenvectors.
  • There is a mention of the potential for confusion if different sign conventions are mixed, emphasizing the importance of consistency in the chosen convention.
Participants express differing views on the implications of sign conventions for momentum operators and spatial translations. There is no consensus on a single approach, as multiple perspectives on the topic are presented.
The discussion highlights the dependence on conventions in quantum mechanics, particularly regarding the choice of signs in operators and their implications for mathematical expressions and physical interpretations. There are unresolved questions about the effects of these choices on the overall understanding of momentum and translations.
Septim
Greetings,
How do we decide on which sign to take when using the momentum operator? The question may be very simple but I need a push in the right direction.
Many thanks.
Thanks for the answer by the way can this convention have something to do with our depiction of the wave function as [itex]e^{i(kx-wt)}[/itex]? I think the statement on the second page of the lecture notes available on the following URL suggests this if I did not misinterpret it. If we selected the complex conjugate of the function then would the momentum operator be the complex conjugate of the previous momentum operator ?
For lecture notes
http://www.phys.spbu.ru/content/File/Library/studentlectures/schlippe/qm07-03.pdf
For lecture notes
I don't like the sequence of ideas in those notes, which (imho) is rather back-to-front. The function you mentioned is better derived by considering eigenstates of the momentum operator. Try the early chapters of Ballentine's textbook for a better (again, imho) sequence of development of the ideas.
This issue also puzzles me whenever I prepare a lecture on the Galileo or Poincare group ;-)). It's just a convention, how you describe spatial translations in terms of its infinitesimal generators, i.e., using [itex]\hat{T}_{\pm}(\xi)=\exp(\pm \mathrm{i} \xi \hat{p})[/itex]. It's arbitrary whether to use the upper or the lower sign convention. The usual one is the + convention.
The action of the translation operator on a generalized position eigenvector is defined by
[tex]\hat{T}_{\pm}(\xi) |x \rangle=|x-\xi \rangle. \qquad (*)[/tex]
For a general state [itex]|\psi \rangle[/itex] this gives for the translation operation on the position-wave function
[tex]\psi'(x)=\langle x|\hat{T}_{\pm}(\xi) \psi \rangle=\langle \hat{T}_{\pm}^{\dagger}(\xi) x|\psi \rangle=\langle x+\xi |\psi \rangle=\psi(x+\xi).[/tex]
For a infinitesimal displacement you have on the one hand
[tex]\psi'(x)=\psi(x+\delta \xi)=\psi(x)+\delta \xi \partial_x \psi(x).[/tex]
On the other that's
[tex]\psi'(x)=(1 \pm \mathrm{i} \delta \xi \hat{p}) \psi(x).[/tex]
Comparing the two latter equations gives
[tex]\hat{p} \psi(x)=\mp \mathrm{i} \partial_x \psi(x).[/tex]
The commutation relations for position and momentum of course also differ by a sign,
[tex][\hat{x},\hat{p}]=\pm \mathrm{i}.[/tex]
As I said, the usual convention is the upper sign.
Of course you can also mix up the whole issue further by using the upper sign convention for the translation operator but a different sign in Eq. (*) on the right-hand side. This again depends on whether you consider the translation as an active or passive operation, i.e., whether you define the translation of the position coordinates with either sign, [itex]x \rightarrow x'=x \pm \xi[/itex].
As I said, that's all convention, and it's good to stick to one once and forever not to get confused.
  • · Replies 32 ·
  • · Replies 56 ·
