| New Reply |
Is 'charged black hole' an oxymoron? |
Share Thread | Thread Tools |
| Jun7-12, 09:01 AM | #1 |
This is a fork-off from someone else's recent thread that seems destined to languish without response in it's new home. Although the initial query there was from a QED angle, the issue of just how or whether a charged BH makes sense needs tackling from GR angle. The established view evidently is that externally observed net charge is invariant wrt whether infalling charged matter is exterior, at, or 'inside' the EH (event horizon). In other words, from a coordinate perspective and presumably quite generally, charge invariance holds for BH's, as determined by appropriately applying Gauss's law to a static bounding surface enclosing any infalling charge and the BH proper. Below are situations imo casting doubt on that position:
1: Matter of proper mass m gently lowered towards the EH reduces in coordinate measure as m' = fm, with f the usual redshift expression f = √(1-2GM/(rc2)). In keeping with that conservation of energy applies and work is being extracted in the lowering process. Now suppose that m also carries a charge q. it makes no difference to the net reduction in m as all forms of energy reduce the same. Locally there is no variation in the proper charge-to-mass ratio q/m. How can that local invariance of q/m (no free-fall case) not be also reflected as remotely observed - i.e. q' = fq? Certainly the locally invariant q/m will show remotely as a proportionately equally redshifted reduction in the Newtonian gravitational and Coulombic forces of attraction/repulsion between two adjacent such charged masses. The implication is obvious - as vanishes coordinate mass, so vanishes coordinate charge. 2: Gently lowering a charged flywheel (or counter-rotating pair to avoid 'twistup'), while feeding it with power so as to maintain constant externally observed mass. Only advantage of this scenario is that explicitly the locally determined proper q/m ratio steadily declines - a direct consequence of locally observed charge invariance. Which as for example 1: implies the failure of global charge invariance whenever gravity is involved. 3: Now for a 'realistic' BH case, one cannot gently lower mass/charge indefinitely and free-fall is the obvious scenario to consider. Coordinate m is then invariant, as potential energy steadily and conservatively converts to KE. Proper q/m is still invariant but that free-fall determination is surely not the right one to apply here. A hovering observer close to the EH, and defining a fixed location on a bounding Gaussian surface of integration, sees a highly relativistic mass infalling past with a small and continually shrinking q/(γm) ratio, where γ = 1/√(1-(v/c)2) is the usual SR expression locally observed. All-in-all then the quasi-hovering scenarios of slow lowering and that of free-fall dovetails together and imo leads to the same conclusion; asymptotic vanishing of externally observed charge as EH is approached. While the extreme case of BH implies the asymptotic vanishing of all infalling charge, a finite redshift factor should apply more generally. Hence for a spherical capacitor, where the inner surface is that of a gravitating mass, one expects from the foregoing a net field exists exterior to the outer spherical shell, owing to greater gravitational depression of the charge on the inner surface, despite equal numbers of charges on both surfaces. The standard position that gravitational redshift of charge does not occur has some ready explanation as to why foregoing is wrong? That would have to be more than simply ab initio enforcing global charge invariance as an axiom I presume? The notion that electric field somehow detaches from source charge and hovers outside a BH EH is perhaps one way of hand-waving an answer. My instant objection would be that for any close distribution of infalling charges, they continue to experience Coulombic fall-off in each other's fields at every stage of infall, something hardly in keeping with a strange delocalization process imo. So, any takers this thread? |
| Jun7-12, 09:18 AM | #2 |
Charged black holes with zero angular momentum are described here: http://en.wikipedia.org/wiki/Reissne...B6m_black_hole |
| Jun7-12, 09:21 AM | #3 |
Hi Q-reeus, this is an interesting question that I hadn't really thought about before, and I haven't seen much about it in the literature.
| Jun7-12, 09:30 AM | #4 |
Is 'charged black hole' an oxymoron?Why do you say that the mass reduces? According to an observer at constant r? Why should charge divided by energy should be globally invariant? Just because it's locally constant, the conclusion does not follow... |
| Jun7-12, 10:18 AM | #5 |
| Jun7-12, 10:18 AM | #6 |
| Jun7-12, 10:18 AM | #7 |
| Jun7-12, 10:58 AM | #8 |
| Jun7-12, 12:06 PM | #9 |
To maintain spherical symmetry, let's suppose instead of a single mass being lowered into the black hole, you instead have lots and lots of little masses arranged in a spherical shell surrounding the black hole. Then they are all lowered into the black hole at the same time, maintaining the spherical symmetry. Then in the case of an uncharged black hole, the mass doesn't diminish as you lower it. From outside the shell of masses, the gravitational field will look exactly like the gravitational field of total mass Mblack-hole + Mshell. Lowering the shell doesn't change the gravitational field outside the shell at all. (I'm using "gravitational field" loosely here; it's actually the metric that's meaningful, not the gravitational field.) I don't know for certain about the case of a charged black hole, but I believe it to be the case that the same thing holds for lowering a charged shell. From outside the shell, the mass of the shell gets added to the mass of the black hole, and the charge of the shell gets added to the charge of the black hole. There is no diminishing of either the charge or the mass as you lower the shell toward the event horizon. In the case of a single mass, instead of a shell, things are more complicated because the mass makes the whole thing not spherically symmetric. However, I think it's still true, that as you lower the mass toward the event horizon, the gravitational and electrical field far from the black hole will approach that of a spherically symmetric black hole with a total mass equal to the original mass and the mass of the particle lowered into the black hole, and with a total charge equal to the original charge, plus the charge of the added particle. |
| Jun7-12, 02:46 PM | #10 |
Must go.
| Jun7-12, 03:20 PM | #11 |
Recognitions:
OTOH, there's definitely no charge leaving the system. According to Gauss, the sum of the field lines going out through some surface doesn't change, no matter how you position the charge inside. Big difference here to the mass case. I'd say clamtrox identified the weakest point in your argumentation: |
| Jun7-12, 03:23 PM | #12 |
by adding up the mass of the component objects. Any time a system does work, its total mass changes. I don't see why black holes are any different in this regard. |
| Jun7-12, 05:16 PM | #13 |
A physicist that is lowered down in a closed laboratory does not see relative strenghts of different forces change.
A physicist that is not lowered down, but dropped down in a closed laboratory, does not see relative strenghts of different forces change. A physicist howering at constant altitude says that bigger force is needed to accelerate an object that is falling fast, than a similar object that is moving slowly at the same altitude. This physicist says that at least one force (inertia ) changes in at leat one of free fall and slow lowering, which leads this physicist to think that probably all forces are equally reduced in a lab that is lowered down. Or does a falling object gain mass? |
| Jun7-12, 09:35 PM | #14 |
I'm still cogitating about this, but I wanted to go ahead and post some general info about the Reissner-Nordstrom metric, which is the unique GR solution for a nonrotating charged BH. I'll also comment on a couple of things in the OP that need clarification/correction.
As noted, the Reissner-Nordstrom spacetime is the unique solution to the Einstein Field Equation for a static, spherically symmetric spacetime where the only stress-energy present is due to a static radial electric field produced by a "point charge" at the origin. (Note that there *is* nonzero stress-energy present; this is *not* a vacuum solution, as the Schwarzschild spacetime is.) The metric in Boyer-Lindquist coordinates (the generalization of Schwarzschild coordinates) is: [tex]ds^2 = - \left( 1 - \frac{2M}{r} + \frac{Q^{2}}{r^{2}} \right) dt^{2} + \frac{1}{1 - \frac{2M}{r} + \frac{Q^{2}}{r^{2}}} dr^{2} + r^{2} d\Omega^{2}[/tex] where M is the mass of the hole and Q is its charge (in geometric units, i.e., Q, like M, has units of length). Note that M is determined the same as it is for Schwarzschild spacetime--put an electrically neutral object in orbit about the hole at a large distance, measure its orbital parameters, and apply Kepler's Third Law--and Q is determined similarly, but using a charged object and the equivalent of Kepler's Third Law for electromagnetism. I'll note in passing that the above metric actually describes three different geometries, depending on the relationship of Q and M. We'll only be considering the Q < M case here; Q = M is a sort of "degenerate" case of that, where the two horizons (we'll see below that there are two for Q < M) merge into one, and Q > M has no horizon, but a "naked singularity" at r = 0. So we assume Q < M, and we find that the above metric describes a spacetime with two horizons, which we'll call r+ and r-. They are at radial coordinates given by: [tex]r = M +/- \sqrt{M^{2} - Q^{2}}[/tex] which is just the obvious solution to the quadratic in r that you get when you set the expression in the metric coefficients above to zero. (You can see, btw, that if Q = M the two solutions are degenerate at r = M, and if Q > M there are no real solutions.) Outside r+, the spacetime works much the same as the exterior region of Schwarzschild spacetime, just with some extra terms in Q. For example, the proper acceleration of a "hovering" observer, who stays at the same radial coordinate r, is: [tex]a = \left( \frac{M}{r^{2}} - \frac{Q^{2}}{r^{3}} \right) \frac{1}{\sqrt{1 - \frac{2M}{r} + \frac{Q^{2}}{r^{2}}}}[/tex] You can see that this will be *less* than the corresponding quantity in Schwarzschild spacetime at the same r coordinate, because both of the terms in Q make it smaller. However, it will still diverge at the outer horizon, r+, because the "redshift factor" still goes to infinity there. It should also be noted that the formula for the "redshift factor" has the extra term in Q in it; the OP does not include this. It's important to be clear about exactly what the proper acceleration above represents. It represents the reading on an accelerometer carried by a "hovering" observer, regardless of *how* that observer maintains his altitude. (For a charged object, as we'll see, it is possible for the object to "hover", if the sign of its charge is the same as that of the hole's charge, purely due to the electrical repulsive force; but the object, if it "hovers", will feel the proper acceleration given above.) For an electrically neutral object, since there are no other forces acting on it, this proper acceleration represents the rocket thrust that must be applied to make it hover. This may seem confusing because the hole's charge, Q, is in the formula; but the reason it is there is that there is stress-energy associated with that charge, as noted above, and that stress-energy affects the spacetime curvature, which affects the motion of *all* objects. In other words, the presence of the charge affects the "force of gravity" as well as the "electromagnetic force", because of the stress-energy associated with the charge. This means that the "mass" M of the hole does *not* represent the entire "source" of gravity associated with the hole, as it does for Schwarzschild spacetime; there is an additional effect due to "stress" associated with the charge Q, which is not accounted for in M. (One might wonder how the above can be true given that, if we measure the orbit of an electrically neutral object, we attribute the orbital parameters only to M. Bear in mind that we stipulated above that the orbit has to be at large r, where the term in Q in the metric is negligible compared to the term in M. Orbits close to the hole *will* be affected by both M and Q, even for a neutral object; at least, it looks to me like they will, but I have not done the detailed calculations to verify that.) Next, we need the force on a charged object due to the charge of the hole. Actually, we'll need the "force per unit mass" on a charged test object, which is the proper acceleration induced by the hole's charge. This is: [tex]a_{e} = \frac{q}{m} \frac{Q}{r^{2}} \frac{1}{\sqrt{1 - \frac{2M}{r} + \frac{Q^{2}}{r^{2}}}}[/tex] where q/m is the charge/mass ratio of the test object. This should be easily recognizable as just the static Coulomb force times the same "redshift factor" that appears above. Just to be clear on the physical interpretation of the above: if q and Q are the same sign, the force per unit mass is directed radially outward, as expected; the hole repels the object. If the signs are opposite, the hole attracts the object (this is in addition to the "attraction" due to gravity). It's important to note that this is a proper acceleration--an accelerometer attached to the object would measure this acceleration if no other forces were acting (i.e., no rocket engines or other sources of proper acceleration). We can put the two acceleration formulas together to find the actual rocket thrust required to make a charged object "hover": [tex]a_{rocket} = a - a_{e} = \left( \frac{M}{r^{2}} - \frac{Q^{2}}{r^{3}} - \frac{q}{m} \frac{Q}{r^{2}} \right) \frac{1}{\sqrt{1 - \frac{2M}{r} + \frac{Q^{2}}{r^{2}}}}[/tex] So an object with the same sign of charge as the hole could potentially hover solely due to the repulsive electric force, without requiring any rocket thrust at all; we can make [itex]a_{rocket}[/itex] vanish by choosing q/m appropriately given a radius r. Conversely, an oppositely charged object will require *more* rocket thrust than a neutral object to hover. In both cases, the key point is that a charged object will *not* free fall in this spacetime if "left to itself" (i.e., no rockets attached or other forces acting on it); unlike a neutral object, a charged object will feel nonzero proper acceleration on its "natural" trajectory. So when the OP says that the "natural" case to consider is free fall, that is not correct for a charged object; the "natural" case there is the trajectory where a_e is the proper acceleration of the object's worldline. This also means that the object's energy at infinity will *not* be constant, unlike that of a neutral object. I'll save deeper analysis for another post, but I wanted to get the basics down while they're fresh in my mind, and for reference so we all have a common basis to work from. |
| Jun7-12, 10:01 PM | #15 |
Recognitions:
Charged black holes are not an oxymoron at all. If we limit ourselves to static geometries (Schwarzschild and Reissner-Nordstom are the cannoical examples), we can describe the results as follows in language that is very similar to the Gauss law formulation.
I'll start out by mentioning that the surface area of a enclosing sphere of r=constant, as measured by local rulers, is well defined and is equal to 4 pi r^2 in the Schwarzschld and Reisser-Nordstrom geometry. The gravitational force in a static geometry is well defined, as there is a well-defined notion of "staying in place". The electric force is always well defined, because we have uncharged test particles that we can use as a reference, the relative acceleration between a charged and an uncharged particle when both are standing still at the same point is entirely due to the electric field. We can note that the product of the area of the enclosing sphere multiplied by the electric force is a constant, and that said constant is proportional to the enclosed charge, Q, of the black hole. This is one illustration that there's no problem with defining the electric charge of a black hole. Aside from working this out for yourself, I'm not sure if there's any quick proof unless you use the notion of differential forms, in which case the proof is trivial. (Finding it may not be trivial.) The area of the enclosing sphere multiplied by the gravitational force is NOT a constant, but the area of the enclosing sphere multiplied by the "force at infinity" IS a constant. This is discussed somewhat in depth in the Wiki article http://en.wikipedia.org/w/index.php?...ldid=465638523. And that's all there is to it. I suspect from the way that the topic keeps popping up that some confusion remains (especially about the second point) but I cant write a description of the physics any more simply than the above. I also have to caution again against applying or trying to apply the above ideas to a non-stationary metric. It Won't Work! |
| Jun7-12, 11:31 PM | #16 |
| Jun8-12, 11:35 AM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Is 'charged black hole' an oxymoron?
| charged black hole | Special & General Relativity | 1 | ||
| Falling into a charged black hole | Special & General Relativity | 0 | ||
| Rotating Charged Black-Hole? | Special & General Relativity | 7 | ||
| Charged black hole | Special & General Relativity | 27 | ||
| Charged black hole | Special & General Relativity | 2 | ||
