| New Reply |
Is 'charged black hole' an oxymoron? |
Share Thread | Thread Tools |
| Jun8-12, 11:35 AM | #18 |
| Jun8-12, 11:36 AM | #19 |
| Jun8-12, 11:36 AM | #20 |
a: My scenario was that of a Schwarzschild BH (but more generally an uncharged central mass M) perturbed slightly by a vastly smaller mass/charge in the process of being lowered/dropped in. Which is not a pre-existing R-N system with central charge already in place. So no conflict there. b: Being highly sceptical of the premise of finite exterior charge for a BH, my use of an R-N model would be rather inconsistent. Anyway, back to your interesting R-N dissection. I concentrate on just the results for proper acceleration a of a neutral test mass, and ae for a charged test mass (agree with pretty much all your other pertinent observations as far as what R-N metric implies.): Regardless though it is all based on there actually being a finite external electric field. We have this R-N expression, and yes one then derives specific interesting results as you have done in #14. My question is, what is the physical basis for that Q lying at the EH can project a finite E to the BH exterior? Still wondering if it comes down to, as I suspected, enforcing global charge invariance as axiom, and out comes R-N. Might be thought a jaundiced outlook, but I get back to scenarios given in #1. Here's another situation worth pondering. A balloon is tethered on a string to the centre of a large mat. Both are electrically charged with the same sign of charge - just sufficient to have the balloon float against earth's gravity. For a distant observer, the mass of earth and balloon are redshifted wrt to that locally observed (not equally of course - much of the earth's mass is already partially redshifted at the balloon location, but that's not important here). Now the balloon is still floating from that observer's pov, so what does that tell us about the value of balloon/mat charge and E fields in coordinate measure? Sleep on it maybe.
| Jun8-12, 11:36 AM | #21 |
| Jun8-12, 12:00 PM | #22 |
I was mistaken in my first response--allowing a dropping mass to do work does change the total mass/energy. As far as the question of whether charge is unchanged by dropping it into a black hole, I'm not exactly sure what you would take as a convincing argument. Charge is a scalar; since charges come in discrete multiples of the charge on an electron, it's just a matter of counting. The charge of something can't change except by emitting or absorbing a charged particle. |
| Jun8-12, 12:04 PM | #23 |
So it's not clear whether you are asking theoretical questions: what does the theory predict? Or are you asking what's really true? Nobody knows what's really true, they just have the current best guess. |
| Jun8-12, 01:10 PM | #24 |
| Jun8-12, 01:12 PM | #25 |
| Jun8-12, 01:31 PM | #26 |
If by "radiative back reaction" you are referring to radiation emitted due to the test object's own field, that would require the object to no longer be a test object; you would have to model its internal structure as well. I think that's way more complication than we need here. ![]() I think the reason that the Q contribution is opposite in sign from the M contribution in the metric is that, if you are at a finite radius r, some of the stress-energy due to Q is above you, whereas all of M is below you, so to speak. Since the spacetime is spherically symmetric, stress-energy above you does not affect the metric at your location. Another way of looking at this is to think of an object collapsing to form a BH, first a neutral object, then a charged object. As I've posted before, when a neutral object collapses to form a BH, the metric you see at a given radius r in the vacuum region, once the object has collapsed, is really due to the SET of the object in the past, before the horizon formed, which is still in your past light cone. It just so happens that that stress-energy leaves behind Weyl curvature, which is static at a given radius once the object has collapsed inside that radius. The M term in the metric reflects that Weyl curvature. However, if a charged object collapses to form a BH, in addition to the Weyl curvature, it leaves a static electric field, which has nonzero stress-energy (Weyl curvature has zero stress-energy) and extends out to infinity. So at a finite radius r, some of that field stress-energy is above you. The Q contribution to the metric tells how much of that field energy is above you, and therefore how much needs to be "subtracted out" from the M contribution to get the actual metric that you see. I emphasize that this is all heuristic and I have not seen or done the actual computation. But that's the sense I get from what I've read. |
| Jun8-12, 02:25 PM | #27 |
The first equation we learned at school: E =F*S, that's very useful.
Energy is redshifted in gravity field. When a vertical rope is tugged from it's lower end, at the upper end tugs of reduced energy are observed. The force F is reduced, not lenght S. If the lower end of the rope has a negative charge, and a posive charge is brought under the lower end of the rope, then at the upper end an increase of weight of rope is observed, and this increace is reduced by the redshift factor. So we conclude that the constant pulling force, transmitted by the rope, of that positive charge is reduced when observed at higher altitude. BUT the pulling force that the positive charge exerts on a negative charge at higher altitude is not reduced. Conservation of charge requires this. BUT at lower altitude it is observed that charges that are being lifted seem to gain more charge, and charges that are being lowered kind of lose charge. Seems the charge of outside universe may change as seen from a gravity well. Interesting. If this needs some justification, then I'll think up some justification. |
| Jun8-12, 03:00 PM | #28 |
| Jun8-12, 07:27 PM | #29 |
| Jun8-12, 08:54 PM | #30 |
After more cogitating, I have a few more items to throw out for consideration.
(1) I'm wondering about the equation I posted for a_e, the proper acceleration on a charged test object due to the hole's electric field. As I've written it, that acceleration diverges at the outer horizon, r+; for like charges, the test object gets pushed outward with infinite acceleration, and for unlike charges, it gets pulled inward with infinite acceleration. That doesn't seem right, and in looking at some papers on arxiv that talk about charged particle motion in R-N spacetime, my equation for a_e may only apply if the test object is momentarily at rest relative to the hole, which would not be possible at the horizon and would allow my formula for a_e to diverge there without actually entailing the consequences I just described. For example, this paper: http://arxiv.org/pdf/1103.1807v3.pdf gives the following equation of motion for a charged test object (I've changed notation slightly from the paper to match my previous posts): [tex]\frac{dx^{a}}{d\tau} \nabla_{a} \frac{dx^{b}}{d\tau} = \frac{q}{m} F^{b}_{c} \frac{dx^{c}}{d\tau}[/tex] where [itex]F^{b}_{c}[/itex] is the electromagnetic field tensor due to the hole's charge, given by [tex]F^{t}_{r} = F^{r}_{t} = - \frac{Q}{r^{2}}[/tex] with all other components zero. My equation for a_e appears to be a valid special case of the above, if [itex]\frac{dx^{0}}{d\tau}[/itex], the "time" component, is the only nonzero component of the 4-velocity of the object; but once the object starts being either pulled in or pushed out, there will be a nonzero radial component of 4-velocity as well, and the formula becomes more complicated. I'm still working that out. (2) In thinking about how a charged object could collapse to a charged BH, I'm wondering if there is an analogue of Birkhoff's Theorem for the R-N case. If there is, it would follow that the "transition" I talked about in an earlier post, between Schwarzschild and R-N spacetime for the case where charged matter falls into a neutral hole, would have to occur much earlier than I thought; it would have to occur at a given radius as soon as the charged matter had fallen inside that radius. I'm also wondering whether there is an analogue of the Oppenheimer-Snyder solution for this case, which would also require an analogue of a collapsing FRW spacetime for charged matter. I haven't found anything useful yet by Googling on either of these items. (3) I'm also looking at trying to express quantities of interest in Painleve coordinates rather than Boyer-Lindquist coordinates, since the latter are singular at both horizons, r+ and r-. The Painleve chart for R-N spacetime looks similar to that for Schwarzschild, just with the extra terms in Q where you would expect them: [tex]ds^{2} = - \left( 1 - \frac{2M}{r} + \frac{Q^{2}}{r^{2}} \right) dT^{2} + 2 \sqrt{\frac{2M}{r} - \frac{Q^{2}}{r^{2}}} dT dr + dr^{2} + r^{2} d\Omega^{2}[/tex] So the "escape velocity" from a given radius r is [itex]\sqrt{\frac{2M}{r} - \frac{Q^{2}}{r^{2}}}[/itex]. See, for example, this paper: http://www.saber.ula.ve/bitstream/12...1/a_family.pdf Another useful site for visualizing R-N spacetime is here: http://casa.colorado.edu/~ajsh/rn.html |
| Jun9-12, 09:17 AM | #31 |
I'm trying to tease apart what parts of your question are mathematical--having to do with how one does calculus in curved spacetime--and what parts of your question are empirical--what experiments tell us. If charge is conserved, then that means that the charge inside of a closed surface is a matter of counting. Counting can't give different answers in different coordinate systems. So of course it's an invariant. So I think the real question is about the various integrals that are used to compute the charge? The following equivalence is provable, for any vector field E: ∫E . dS = ∫(∇.E) dV (The flux of E through a surface is equal to the integral of the diverge of E over the volume enclosed by that surface) In relativity, the electric field is not actually a vector, but 3 components of a 6 component tensor Fαβ, but there is a corresponding fact about tensor fields. The equivalence of the two integrals is a coordinate-independent fact that's provable using calculus, and it works the same in curved spacetime. So, is your question really about Gauss's law: Are you asking whether we have proof that ∇.E = 4∏ ρ where ρ = the charge density? Or are you asking whether the electric field E is really part of a tensor field Fαβ? There are a lot of interrelated concepts that are involved in the conservation of charge in curved spacetime, some of them are provable using calculus, and some are empirical. The empirical part I think is captured by Maxwell's equations, together with the Lorentz force law. If those hold (or rather, their generalization to curved spacetime), then conservation of charge and invariance under coordinate changes is a matter of pure mathematics--if they are true, then it's provable using calculus in curved spacetime. I think that they are true, but the detailed proof is not something I have personally have worked through. Turning that claim around, if charge is not conserved, or if it is not an invariant, then I believe that is only possible if Maxwell's equations or the Lorentz force law are false. Those have only been tested near Earth, which only has fairly mild gravity, so there is no guarantee that they hold in regions of very strong gravity. |
| Jun9-12, 09:20 AM | #32 |
| Jun9-12, 11:11 AM | #33 |
| Jun9-12, 11:11 AM | #34 |
| New Reply |
| Thread Tools | |
Similar Threads for: Is 'charged black hole' an oxymoron?
| charged black hole | Special & General Relativity | 1 | ||
| Falling into a charged black hole | Special & General Relativity | 0 | ||
| Rotating Charged Black-Hole? | Special & General Relativity | 7 | ||
| Charged black hole | Special & General Relativity | 27 | ||
| Charged black hole | Special & General Relativity | 2 | ||
