| New Reply |
Is 'charged black hole' an oxymoron? |
Share Thread | Thread Tools |
| Jun9-12, 11:11 AM | #35 |
| Jun9-12, 11:19 AM | #36 |
| Jun9-12, 04:46 PM | #37 |
the invariance of charge. The current theory, which does have invariance of charge, works perfectly fine in all cases that we are capable of analyzing--there is no reason to believe that there is any problem. Of course, that doesn't mean that our current theories are correct, but there is no indication of any inconsistency in them (which is what I thought you were claiming). of relativity theory. So it seems to me that it would be more productive for you to understand relativity better, rather than for me to understand your misunderstandings. |
| Jun9-12, 04:49 PM | #38 |
| Jun9-12, 05:10 PM | #39 |
I apologize if my response was a little grumpy. I guess I'm being a little impatient. I guess I should read what his been said more carefully before replying.
| Jun9-12, 05:19 PM | #40 |
| Jun9-12, 05:24 PM | #41 |
| Jun9-12, 08:04 PM | #42 |
| Jun9-12, 11:17 PM | #43 |
Let me explain: 1: A hydrogen atom is lowered into a deep gravity well. Then a photon of visible light is dropped onto the atom, which becomes ionized, although visible light does not normally ionize hydrogen. That happened because the field that keeps the atom together weakened as the atom was lowered. 2: A hydrogen atom and a photon of visible light are both gently lowered into a gravity well. Now the photon does not ionize the atom. The reason for this is that the electric field of the photon weakened as the photon was being lowered, as did the electric field in the atom. So a photon in a gravity well, observing an atom being lowered into the gravity well, will say that the force that keeps the atom together is weakenig, kind of like the charges in the atom were becoming smaller. (if photon does not have an electric field, then replace photon with a EM-wave pulse) (photon can be lowered using a mirror lined elevator) |
| Jun9-12, 11:29 PM | #44 |
| Jun10-12, 12:40 AM | #45 |
Well this is what I think: A person that has spend some time in a deep gravity well will be observed having aged abnormally slowly, after he has been winched up from the well. He has produced some EM-waves by waving his slightly charged hands. Not very many EM-wave crests have been observed outside the gravity well, and the person does not report that he waved his hands very many times. So the EM-waves that came up from the gravity well had just a few wave crests, because the person waved just a few times. And this is the reason the EM-waves that came up were slowly waving waves: Few crests during a long time, because of the slowness of the wave source. The waves become longer at higher altitude, because light moves faster at higher altitude. The case of free falling atom and photon I have to think about a bit. |
| Jun10-12, 07:44 AM | #46 |
| Jun10-12, 08:03 AM | #47 |
Look, the same thing happens in Newtonian gravity. If I throw a small stone at a car, it won't do much damage. But if I drop that stone from a great height, it can do a lot of damage. I would not describe this as "the forces holding the car together get weaker when the car is deep in a gravitational well". The only meaningful notion of the "strength of forces holding an object together" is what you measure at the object, in the (local) inertial frame in which the object is at rest. That is not changed by dropping the object into a deep gravitational well. What changes between high in the well and lower in the well is the translation of vectors. A velocity vector that is a small velocity high up in the well translates to a much larger velocity deeper down. Of course, General Relativity understands gravity in a different way than Newtonian physics, but in neither case is it appropriate to say that "forces holding an object together get weaker when the object is lowered in a gravitational field". |
| Jun10-12, 08:29 AM | #48 |
An alternative way of thinking about curved spaces is in terms of gluing together lots of approximately flat spaces. Imagine taking the surface of the earth and breaking it up into lots of triangles of size 10 miles on a side. Now, within each little triangle, Euclidean geometry works fine. Straight lines look like straight lines on a map for that triangle. The "curvature" part is captured by how the various triangles are glued together. If a traveler leaves one triangle, you need to figure out which triangle he enters next, and what angle his trajectory makes in the second triangle. So there is a "translation" process to translate vectors from one region of a curved space to another. In GR, a photon's momentum is a certain vector, that has to be translated when that photon moves from one region to another. That's what the redshift/blueshift formula is doing. |
| Jun10-12, 09:06 AM | #49 |
Nobody seems to know how the total energy of a falling rock changes. Obviously that energy that is responsible of car crushing does increase. Light is more simple: When light enters a gravity field of a planet, the light slows down and the planet starts to move in the same direction as the light. So light loses energy when falling. Or as an extremely good aproximation the energy stays the same. There was a long and technical discussion in this forum about the energy change of falling light, and those were the conclusion. The light losing energy is my own idea though. So it must be the objects becoming weaker at lower altitude, which causes them to break more easily, when light from above hits them. Hey I have one more scenario again: A charge in a gravity well is accelerated from 0 m/s to 100 m/s. Radiation energy is proportional to velocity change. As seen from higher altitude the velocity change was smaller than 100 m/s, and there is the reason why the radiation energy coming from the gravity well is smaller too. |
| Jun10-12, 09:46 AM | #50 |
Mentor
| Jun10-12, 09:55 AM | #51 |
Suppose that mass/energy in a slowly lowered mass m is in the form of an unstable matter/antimatter doublet that self-annihilates and escapes entirely 'to infinity' as gamma rays. We surely agree that in escaping the gravitational potential well of central mass M, those rays - which carry all the energy tied up originally in m(r), are redshifted in coordinate measure. Annihilate the same matter/antimatter doublet out there in distant space, and obviously the gamma rays are not redshifted at all. This little experiment of the mind imo nicely indicates it is proper to consider the energy loss/gain in lowering/raising matter/energy of mass m(r) in a grav well as essentially confined to just that mass m(r) - provided m(r) << M. Unless that is one wishes to argue transporting matter/energy from a resting position at one potential to a resting position at another potential can be anything but a path independent process - assuming of course central mass M is taken as static. Again if one argues those gamma rays are not 'resting' just remember we are free to have them absorbed by nuclei in a massive block of matter etc. which then constitutes resting position. You might also care to look again at the parallel-plate capacitor situation of last para in #24. We agree that locally, it only makes sense to ascribe energy loss (transfer of energy to higher up via electrical line) upon capacitor discharge to be confined essentially to the capacitor field-charge system, not say the planet of mass M as a whole. Again, haul the charged capacitor up to higher potential, then discharge. More power available - gained via the hauling process - and to be located in the capacitor field. It's only when masses are roughly comparable that delocalization/sharing becomes significant. There has been some nitpickery over fine distinctions between mass and energy but let's recall the scenario 1: in #1 to which you have at least specifically addressed in #40 as quoted above - it's one of slow lowering. For which it's then perfectly appropriate to treat the mass/charge as momentarily resting at a given height. What then is the distinction between rest mass and total stress-energy? Sure there must be stress in the matter involved (it feels 'g' forces) and yes technically that comes under a different part of the stress-energy tensor contribution to total gravitating mass m(r). It will though be typically extremely small compared to the rest energy part, and anyway acts here simply as a scalar additive term. So can we please just take it that m(r) is inclusive of rest energy and stress without further fuss and ado? Re your's and to some extent PeterDonis's criticism of jartsa over his description of atoms being 'weaker' further down. The local perspective is not the only legitimate one and from a coordinate viewpoint I would agree with his thrust. There is something similar in SR. A slab of dielectric lies immersed in an E field of a parallel plate capacitor. Both dielectric and capacitor are stationary in lab frame S', and E' there is below dielectric breakdown value. Now propel that slab to a relativistic velocity in S', normal to direction of E' such that in proper frame S of slab, E exceeds breakdown value and there is catastrophic failure and discharge. It is not legitimate to say that in S' the slab can be viewed as having 'weakened', since E has not changed in S'? Notice too that in jartsa's scenario if an atom spontaneously decays radioactively releasing a gamma ray, it is redshifted as seen from outside of potential well. That can legitimately qualify it as a 'weaker' atom with weaker internal EM and nuclear fields in my book - it's all a matter of pov. There is a potential can of worms I'm uncovering or rather rediscovering in working through all the ways of looking at how mass, energy, momentum, field etc. should be evaluated in coordinate measure - more later. Maybe much later. |
| New Reply |
| Thread Tools | |
Similar Threads for: Is 'charged black hole' an oxymoron?
| charged black hole | Special & General Relativity | 1 | ||
| Falling into a charged black hole | Special & General Relativity | 0 | ||
| Rotating Charged Black-Hole? | Special & General Relativity | 7 | ||
| Charged black hole | Special & General Relativity | 27 | ||
| Charged black hole | Special & General Relativity | 2 | ||
