New Reply
Circuits with Series and Parallel Wiring
Share Thread Thread Tools
Jun9-12, 07:35 PM   #18
Quote by Snape1830 View Post
Well, 4+6=10.
So...
20=10I
I=2 A
But 2 is wrong, so I don't know.
Now you got 2 Amps flowing through the equilvalent parallel resistors and through 6 Ohms resistor.
Now what is the voltage across each of the parallel resistors?
From this voltage drop, you calculate the current flow.
What is required here is to find the current flowing through the equivalent parallel resistors of two 10 Ohms resistors.
Jun9-12, 07:43 PM   #19
Quote by azizlwl View Post
V-RI
V=10(2)
V=20 V
V=20(2)
V=40 V
So across the 10 ohm resistors, the voltage drop is 20 V
Across the 20 ohm resistor the voltage drop is 40 V?
That 40 can't be right, though?
Jun9-12, 07:50 PM   #20
Wrong.
With equivalent parallel resistors, you have only 2 resistors. 6 ohms and 4 ohms.
What is the voltage drop across 4 ohms resistor.
This voltage drop is identical to all the resistors in parallel.
Remember the voltage across all resistore in parallel are equal.
Jun9-12, 08:38 PM   #21
Wrong.
Oh, right, I misread the question.
V=2(4)
V=8 Volts
Jun9-12, 10:43 PM   #22
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
V=2(4)
V=8 Volts
So the voltage across the resultant of the parallel resistors is 8 V. You get the current through each of them if you divide that 8 V by the resistances.
What is the current that flows through the ammeter?
Remember Kirchhoff's nodal law.
ehild
Jun10-12, 08:18 AM   #23
Quote by ehild View Post
ehild
Kirchoff's loop rule? The current going in equals the current coming out.
So do I find the current through of the parallel resistors and then add them up...because that comes out to 2 and 2 is wrong.
Jun10-12, 08:25 AM   #24
Recognitions:
I wrote Kirchhoff's node rule.
The ammeter measures the current that flows through it. Does I20 ,represented by the green arrow flow through the ammeter?
ehild
Jun10-12, 08:30 AM   #25
Wrote Kirchhoff's node rule.
ehild
No? So it would be 1.6 A?
And thanks for taking the time to edit the picture!
Jun10-12, 08:41 AM   #26
Recognitions:
Correct .
ehild
Jun10-12, 08:52 AM   #27
Correct .
ehild
Ok! So now part b how much power dissipated through a 10 ohm resistor. The power equation.
P=IV
or
P=I2(r)
or
P= v2/R
I tried a few answers but none of them work.
Jun10-12, 09:16 AM   #28
Recognitions:
What is the voltage across the 10 ohm resistor?
ehild
Jun10-12, 09:18 AM   #29
ehild
8? It seems wrong for some reason
Jun10-12, 09:18 AM   #30
Recognitions:
P=IV
or
P=I2(r)
or
P= v2/R
They don't?
How much current is flowing in just one of the 10Ω resistors?
Jun10-12, 09:22 AM   #31
Quote by NascentOxygen View Post
They don't?
.8 amps?
Jun10-12, 09:26 AM   #32
Recognitions:
.8 amps?
Then I2·R =
and what makes you think this isn't right?
Jun10-12, 09:27 AM   #33
Then I2·R =
It would be 6.4, and it's wrong because I plugged in the answer and it said it was wrong.
Jun10-12, 10:29 AM   #34
Recognitions:
6.4 watts is correct.
New Reply
Tags
circuits, current, parallel, power, series
Thread Tools
Similar Threads for: Circuits with Series and Parallel Wiring
Thread Forum Replies
Series parallel switch wiring Electrical Engineering 0
Circuits with series and parallel wiring Introductory Physics Homework 1
Circuits with Series/Parallel Wiring Introductory Physics Homework 3
Parallel and Series Circuits Introductory Physics Homework 2
correct series-or-parallel-or-off switch wiring? Electrical Engineering 6
