| New Reply |
Parallel transport and geodecics |
Share Thread | Thread Tools |
| Jun10-12, 05:25 AM | #35 |
| Jun10-12, 08:09 AM | #36 |
Mentor
| Jun10-12, 08:46 AM | #37 |
Mentor
Yay, I just thought of an example: a Moibus strip.
So, you can take a Moibus strip and draw a geodesic around the strip. The tangent vector is parallel transported along the geodesic, and so obviously it parallel transports to itself. A vector orthogonal to the tangent vector is parallel transported such that its dot product with the tangent vector remains the same (0), but it winds up on the opposite side of the tangent vector. So it does not map to itself despite the tangent vector doing so and the dot product remaining the same. |
| Jun10-12, 09:20 AM | #38 |
Of, relating to, or denoting the shortest possible line between two points on a sphere or other curved surface. So how is a great circle not a geodesic but just an "analog" of a geodesic???? What am I missing? |
| Jun10-12, 11:10 AM | #39 |
| Jun10-12, 11:23 AM | #40 |
| Jun11-12, 09:22 AM | #41 |
Recognitions:
Shifrin comments on this in his notes, Corollary 1.5 and the paragraphs following on p79-80.
http://math.berkeley.edu/~reshetik/1...rinDiffGeo.pdf |
| Jun11-12, 09:54 AM | #42 |
Mentor
| Jun11-12, 11:01 AM | #43 |
I treated the two sides of the strip as "two layers" which represent different regions of the same manifold: Walking on the strip will bring you to your original position (on the same side) without flipping the orthogonal vector. |
| Jun11-12, 11:04 AM | #44 |
Mentor
| Jun11-12, 01:57 PM | #45 |
. it seems that a complete circuit returning to the starting point does retain an orthogonal vector on the same side as the original. |
| Jun11-12, 02:14 PM | #46 |
Mentor
No, you have to go two complete circuits to get an orthogonal vector back to the same side. I don't know how to describe how it works, but you can see for yourself. Use a piece of transparent material so that you don't have to worry about the fact that a piece of paper is a 3D object and has two flat sides whereas a flat 2D manifold does not.
| Jun11-12, 02:22 PM | #47 |
i am just trying to get the picture here. |
| Jun11-12, 02:24 PM | #48 |
DaleSpam is thinking about moving within the strip. The loop you travel here is just half the length of the loop "on the surface", and you arrive flipped. |
| Jun11-12, 02:32 PM | #49 |
| Jun11-12, 02:33 PM | #50 |
But then i'm not sure what you talking about as there seems to be a difference of view here. AN early post mentioned a geodesic as a helical world line which I get. The path of an inertial particle. Then PeterDonis seemed to indicate you were not talking about this but some other concept in the context of geometric topology . SO ??? When you talk about geodesics on a sphere aren't you talking about the surface as a 2 d topology? Thanks |
| Jun11-12, 02:35 PM | #51 |
Then wrt closed geodesic: a) it's world line would be a set of point worldlines together comprising a tube. b) it is a single entitiy whose world line is a tube. c) It is an abstraction that can't really be said to have a worldline. so does parallel transport include a velocity term? |
| New Reply |
| Thread Tools | |
Similar Threads for: Parallel transport and geodecics
| Parallel transport | Differential Geometry | 14 | ||
| Parallel transport | Special & General Relativity | 14 | ||
| Parallel Transport | Special & General Relativity | 20 | ||
| parallel transport | Introductory Physics Homework | 0 | ||
| Lie transport vs. parallel transport | Differential Geometry | 10 | ||
