Force on a wire carrying current
  • Context: Undergrad
  • Thread starter Thread starter ehabmozart
    Current Force Wire
The force on a wire carrying current is defined by the equation F = BIL sin θ, where θ is the angle between the magnetic field (B) and the current (I). The maximum force occurs when the current is perpendicular to the magnetic field (θ = 90°), resulting in F = BIL. Conversely, when the current is parallel to the magnetic field (θ = 0°), the force is zero, as there is no component of the current cutting across the field lines. Understanding these principles is crucial for analyzing the behavior of charged particles in magnetic fields.
  • Understanding of vector components in physics
  • Familiarity with magnetic fields and forces
  • Knowledge of the right-hand rule for magnetic forces
  • Basic principles of electromagnetism
  • Study the right-hand rule for determining the direction of force on charged particles
  • Explore the concept of magnetic flux and its relation to current-carrying wires
  • Investigate the motion of charged particles in magnetic fields using F = Bqv
  • Review illustrative diagrams of current and magnetic field interactions
Students of physics, electrical engineers, and anyone interested in the principles of electromagnetism and the behavior of current in magnetic fields.
ehabmozart
It is given in my book. hat F=B I l sin theta where theta is the angle between B and the current I... I guess this is no right.. I mean, how would the current make an angle with B, it should b the length of wire itself... Secondly F=Bqv is the reason behind a charged particle which enter perpendicularly to a magnetic field moves in a circle.. My doubt is that at point, this point charge will be inline with the field line.. From where will it get force at that point.. Talking about the quarter circle... I need more clarification and it would be more than amazing if there are some illustrative diagrams!
The angle in your first equation IS the angle between the current and the field lines. If you imagine a uniform B field you can also imagine a wire in this field pointing in various different directions.
Current is a vector, and only the component of the current vector that cuts across the field lines causes the force. When the current is at right angles to the field, θ = 90 and sin θ =1. This means that all of the current contributes to the force so you get the maximum force = BIL.
On the other hand, when the current is parallel to the field, θ = 0 and sin θ = 0. This makes your force = BIL × 0 = 0 as there is no component of the current cutting across the field lines.
  • Sticky
  • · Replies 0 ·
  • · Replies 61 ·
