| New Reply |
Proving something cant be written as a square |
Share Thread |
| Jun11-12, 04:49 AM | #18 |
| Jun11-12, 04:49 AM | #19 |
I used modular arithmetic this time, along with reductio ad absurdum.
Here is the first thing I did. I used the properties of the expression you gave as follows: [tex]n^2=p^{m+a}-p^m+3p^a+1[/tex] [tex]n^2-1=(n-1)(n+1)=p^{m+a}-p^m+3p^a=p^a(p^m-p^{m-a}+3)[/tex] From here, you see either n-1, n+1, or both are divisable by p (since a is nonzero.) If both were divisable, it would imply p=2, which you stated can't be true; since p is an odd prime. I hope you can carry the proof on. |
| Jun11-12, 04:51 AM | #20 |
I would be happy if you can elaborate and send me the proof. |
| Jun11-12, 05:05 AM | #21 |
| Jun11-12, 05:09 AM | #22 |
You don't need to prove it for n+2.
| Jun11-12, 05:13 AM | #23 |
| Jun11-12, 05:15 AM | #24 |
That is the part which you should answer.
| Jun11-12, 05:18 AM | #25 |
| Jun11-12, 06:07 AM | #26 |
I remember a and m to be non negative, and I don't remember this m=2n+a for some integer n So anyway, when I said a=0 disproves it, I was not talking about the proof given later, it wasn't yet here anyway, I was just pointing at the fact that you were trying to prove something which is not true as stated Do you have any context for this question ? are you being stuck in the middle of a 'bigger' proof that would rely on this to be validated ? or is this the real exercise ? can you state it exactly as it comes ? If it is an exercise, in which context does it come ? you are often asked to apply some recently learnt theorem or rule or lemma.. that would help everyone I think. Meanwhile, I didn't look closely at the other proof you say turned out to be wrong or incomplete, but I saw among comments that there was something about odd/even numbers, so one thing is certain, for this expression to be a square of some integer, this integer has to be even. Cheers... |
| Jun11-12, 11:32 AM | #27 |
| Jun11-12, 12:11 PM | #28 |
Hurray , I got it sir. Perfectly this time I have got it.. I know the complete proof for all the things now. I completed the whole proof. It does involves the even and odd manipulations. But its very easy and not complex.
I just used to show that $P^a$ doesnt divide an even number in both (n+1) and (n-1) case. It turned out to be right perfectly from some series of arguments. |
| Jun12-12, 02:28 PM | #29 |
So let us show that this fails in the case of [itex]n^2[/itex]. Let us start with the equation [itex] p^{t+\phi}-p^{t}+3p^{\phi}+1[/itex]. If that is a square it would be equal to some n^2 for some even [itex]n[/itex]. [itex] p^{t+\phi}-p^{t}+3p^{\phi}+1=n^2[/itex]. We prove that it will not happen based upon two cases. Let us simplify it further. [itex]p^{\phi}(p^t-p^{t-\phi}+3)= n^2-1[/itex] \begin{equation} p^{\phi}(p^t-p^{t-\phi}+3) = (n+1)(n-1). \end{equation} From the above equation its evident that [itex]p^{\phi}[/itex] may divide either [itex](n+1)[/itex] or [itex](n-1)[/itex]. So there are two cases possible. \subsubsection{ Dividing n-1 } As we said that [itex]p^{\phi}|(n-1) [/itex] . From here the proof turns out to be interesting. We know that [itex]n[/itex] is even, hence [itex]n-1[/itex] would be odd. So if [itex]p^{\phi}[/itex] divides [itex](n-1)[/itex] in [itex](n-1)(n+1)[/itex] it must give rise to some new term of the form [itex]d.(n+1)[/itex] where [itex]d[/itex] is odd ( Since, odd number divided by odd number would give rise to odd number ). So that [itex]d.(n+1) = (p^t-p^{t-\phi}+3) [/itex] (since from (2)). So let us prove that its a contradiction. [itex]d.(n+1) = (p^t-p^{t-\phi}+3)[/itex] [itex]d.(n+1) = p^t(1-p^{-\phi})+3[/itex] [itex] d.(n+1)-3= p^t(1-p^{-\phi}) [/itex]---(3) So here its evident that [itex]p^t | d.(n+1)-3 [/itex] . So the equation (3) can be written as [itex]M.(d.(n+1)-3)=(1-p^{-\phi})[/itex]. Where it divides [itex]M[/itex] times ( [itex]M[/itex] can be even [itex]1[/itex] in which the same equation is obtained ). So its clearly evident that L.H.S is an integer. So the R.H.S is [itex] \frac{p^{\phi}-1}{p^{\phi}}[/itex]---(4) So its evident that a prime number minus one is an even number. Prime numbers are nothing but in some sense odd numbers. So odd number minus one would be an even number. So the numerator in the (4) is a even number and denominator is the odd number. So it would never turn to an integer. Which is a contradiction. |
| Jun12-12, 02:31 PM | #30 |
| Jun12-12, 06:20 PM | #31 |
Recognitions:
E.g. 18 = 33-32 = 33(1-3-1), but 33 does not divide 18. |
| Jun12-12, 08:10 PM | #32 |
Strange thread indeed. Have you agreed on what statement you are looking to prove? For example, when p=3, m=a+2 then (p^m+3)(p^a-1)+4 is a square, so you may want p>3 in your original statement.
| Jun12-12, 11:40 PM | #33 |
| Jun12-12, 11:43 PM | #34 |
| New Reply |
Similar discussions for: Proving something cant be written as a square
| Prove that any square matrix can be written as the sum of a symmteric and a skew-symm | Calculus & Beyond Homework | 8 | ||
| Help with proving a function can be written f = E + O | Precalculus Mathematics Homework | 19 | ||
| Every integer can be written as a sum of a square and square free integer | Calculus & Beyond Homework | 5 | ||
| help needed in proving a number to be perfect square | General Math | 12 | ||
| Proving a perfect square with factorials | Introductory Physics Homework | 3 | ||
