An EASY work and energy problem. Is my answer correct?
The discussion revolves around a work and energy problem involving a block sliding down a ramp. The block has a mass of 2.04 kg and descends from a height of 4.77 m, with friction doing 20 J of work. Participants are questioning the calculated speed at the bottom of the ramp.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of kinetic energy and the impact of friction on the total energy. There are inquiries about the correct application of work-energy principles and the relationship between gravitational potential energy and kinetic energy.
Some participants have provided guidance on incorporating the work done by gravity and friction into the energy equations. Multiple interpretations of the problem are being explored, particularly regarding the conceptual understanding of work done by different forces.
There is a focus on ensuring that all forces, including friction and gravity, are accounted for in the calculations. Participants are also discussing the implications of the signs in the equations used.
DLxX
I need to know if my answer is correct for the following problem.
A 2.04 kg block slides down a ramp from a height of 4.77m. If friction does 20J or work, what is the speed at the bottom of the ramp?
I keep getting 9.7m/s. Is this correct?
I'm not getting that. Can you show what you did?
I found the work with the W=Fd formula and then used that value for work in the formula W=Ekf - Eki (kinetic energy) (.5mv^2).
What would the KE be,if it hadn't been friction on the inclined plane...?
Daniel.
Ah, you didn't take friction into account.
You need to include the work done by gravity as well as work done by friction on the left hand side. Be careful with signs.
mgh-20 = Ekf - Eki
Daniel.
95.4? I found that using the Gravitation Potential Energy Formula since I don't know the velocity yet, and since the grav pot should be equal to the kin pot at the end. Right?
mgh-20 = Ekf - Eki
I did that and got the correct answer of 8.6m/s, but would one of you mind explaining the theory behind subtracting the force of friction from the Grav Pot Energy? Should I just think of it like Net force or something?
To get total work done, you can get work done by each force... you don't know the frictional force... but you're given that it does -20J of work. Only other force left is gravity which does mgh of work (force of mg through a distance of h). So total work is mgh-20.
Two ways to think about this problem come to mind to me. First way is just total work on object = change in kinetic energy... here we count all the forces acting on the object including gravity. This is how you did the problem.
Second way is when we use gravitational potential energy. I'll call mechanical energy= K.E + G.P.E
MEfinal - MEinitial = work done by all forces except gravity.
Both ways give the same answer. You can verify this.
Work done by gravity through a distance h is mgh. (force=mg distance=h). Just wanted to point out that mgh here is not being used as GPE but as work done by gravity.
The math comes out the same, but it gives two slightly different ways of thinking of the problem.
  • · Replies 32 ·
  • · Replies 56 ·
