Physical representation of direction
The discussion revolves around the physical representation of direction for particles in motion, particularly how direction information is stored and represented in the context of classical mechanics and quantum mechanics. Participants explore the implications of momentum, inertia, and the nature of motion in both classical and quantum frameworks.
  • One participant questions how a particle 'remembers' its direction of travel, suggesting a physical representation of direction must exist.
  • Another participant states that the momentum vector is constant in the absence of forces, serving as a mathematical representation of direction.
  • A different viewpoint emphasizes the physical difference between particles moving in opposite directions, arguing that there is no 'knowing' or 'storing' of information in the universe, referencing Newton's first law.
  • Some participants express uncertainty about the fundamental nature of motion, suggesting that the deep nature of how particles move, especially in a vacuum, remains a mystery.
  • One participant proposes a connection to General Relativity and questions what causes inertia, indicating a potential link between classical and relativistic concepts.
  • Another participant highlights the implications of quantum mechanics, noting that particles do not 'know' their position or direction due to wave packet spreading and the nature of quantum states.
  • There is a discussion about the possibility of modifying direction without affecting magnitude, with one participant expressing curiosity about 'inertial reflection' and its implications for space travel.
  • Counterarguments are presented regarding the feasibility of changing direction without energy absorption, emphasizing the conservation of momentum and the inherent costs associated with such changes.
Participants express a range of views on the nature of direction and motion, with no consensus reached. Some agree on the role of momentum, while others challenge the assumptions about direction storage and modification.
The discussion includes unresolved questions about the fundamental nature of motion, the representation of direction in different frameworks, and the implications of conservation laws. There are also references to classical and quantum mechanics that may not fully align.
ealbers
Please forgive such a simple question, but how does a particle 'remember' what direction to travel in from instant to instant?
I mean, say we take 2 particles way out in space, we kick one say along a +x axis, and the other with the same force along the -x axis...
How is the Direction information physically represented in each particle, I mean, we give each the same energy, only difference is the vector, where is that direction vector physically stored from moment to moment?
Thanks, apologies again for the basic question.
Eric
It's the momentum vector, which in the absence of forces is a constant.
Yes, the momentum vector is the mathematical representation of the direction, my question is, what is PHYSICALLY different between the two particles? How is that mathematical vector represented?
My guess is some kind of spacetime curvature storing the vector info??
From each particles perspective, it can be viewed as 'stationary' and the other 'moving'...but having both particles have this view does not represent the manner in which the direction of motion is 'stored' by the universe...and stored it must be, for from moment to moment forever (without outside forces), the particles will continue on their path...so perhaps when you impart motion to one, it somehow stores its direction vector into the curvature of space around it? i.e. energy given (and vector direction) is stored into a 'field' or 'virtual direction particle' around the moving particle??
I know it seems a senseless question at first...and perhaps that's more due to the senselessness of the person asking the question :-)
Thanks
Eric
Well the simple answer is the two particles are different because one is moving one way and one is moving the other. There is no 'knowing' or 'storing' of information in the universe. If you push it one way it goes that way because (simply) Newton's first law.
There appears to be a void of how 'particles' move, esp, in vacuum. I don't think anyone can explain how this technically happens. The deep nature of motion is a mystery but if you use Newton's laws and/or the equations of SR(say in the LHC), you'd be able to predict their behavior.
This comes from right out of nowhere, so it may be total nonsense:
With reading your mention of a curve I thought that perhaps you might be thinking of a General Relativity formula for the path of a massive object in a gravitational field (does GR cover that?), but solved with a value of zero for the gravitational field. Sounds like taking a long way to get back to Newtonian as mentioned above.
Perhaps your question is "What causes inertia?"
DC
The picture of 2 particles moving in opposite directions on the x-axis is more classical that QM.
In QM, there is no knowing of info from "moment to moment". If, at one time, you measure the momentum of the above 2 particles precisely then their position (along the x-axis) is completely unknown, i.e. they do not "know" where they are.
Also, for individual particles traveling freely, you get wave packet spreading. So, in a sense, they are traveling in many directions at the same time.
If you want to also consider Feynman's Path Integral Formulation of QM, in the absence of other info, particles travel all possible paths between 2 (space-time) points. An equivalent statement is that the particles don't "know" what direction their traveling in.
Sorry for the strange question, I was curious if the direction information could be modified without the magnitude being effected...so the vector 1,0,0 could somehow be reflected to be -1,0,0 without the magnitude of the motion being effected. Understanding how direction is stored would give some insight into the ability to do 'inertial reflection'
If we ever want to really travel in space, we need some way to change the direction of incoming particles without having to absorb and re-emit their energy, finding a 'cheap' way to modify the direction vector alone would do this, though the how is tied to the how direction being represented...
Thanks
Eric
Science doesn't work like that. The magnitude of two equal and opposite vectors is the same, but that's purely a mathematical similarity, the two vectors are completely different. This 'inertial reflection' you speak of simply isn't possible.
Thanks
Eric
You can't get away from the conservation of momentum, it is built into the homogeniety of space. Anything that moves and has energy has momentum. Change in direction = change in momentum. There is no "cheap" way to change the direction of an incoming particle. The "cost" is always equal to the net change in momentum (direction and magnitude).
  • · Replies 27 ·
  • · Replies 24 ·
