The Possibility and Potential Implications of Cold Fusion
  • Context: Graduate
  • Thread starter Thread starter Jack
    Cold Fusion
The discussion revolves around the possibility of cold fusion, exploring its feasibility, potential mechanisms, and implications for energy generation. Participants examine theoretical aspects, experimental evidence, and alternative interpretations of cold fusion phenomena.
  • Some participants question the feasibility of cold fusion, citing the challenges of overcoming the repulsion between like particles and the need for significant kinetic energy for fusion reactions.
  • Others propose alternative mechanisms, such as the possibility of cold fission or cold alpha radiation, suggesting that solid-state effects might play a role.
  • A participant emphasizes the need for free neutrons in proposed cold fusion reactions, arguing that generating them would require energy investment, complicating the energy return.
  • There are references to historical experiments, such as the Fleishmann-Pons experiment, which produced helium and energy but left room for alternative explanations like catalysis of alpha disintegration.
  • Some participants express skepticism about the concept of cold fusion, with one stating it is a contradiction in terms, while another asserts its possibility, citing the paradox of its implausibility.
Participants express a range of views on the possibility of cold fusion, with no consensus reached. Some firmly believe it is impossible, while others argue for its potential viability, leading to a contested discussion.
Participants highlight various assumptions and limitations in their arguments, such as the dependence on specific definitions of fusion and the unresolved nature of energy generation mechanisms in cold fusion scenarios.
Do you think cold fusion will become a reality?
  • Absolutely!
    Votes: 2 18.2%
  • Possibly
    Votes: 3 27.3%
  • Probably not
    Votes: 5 45.5%
  • Alsolutely not
    Votes: 1 9.1%
  • Total voters
Jack
Do you think that cold fusion is posible?
Also, if it is what would some of the implications of this be, how would it change our world?
The most obvious obstical to overcome would be the repulsion of like particles. The reason fusion is hot to begin with is because fusion reactions don't happen unless there is enough kinetic energy to get the protons close enough to fuse. Now if you could get crafty and have two neutrons come together then somehow get them to decay at the same time into protons, electrons, and (ok I always forget this part but I think its a muon or a pion or something-on), this may work. Because the there is no em repulsion between two neutrons, thus you wouldn't need all of that kinetic energy which basically translates to heat.
Of course this means manipulating things below the nuclear level and I just don't think it can be done (with what we know today).
The intense heat needed for a fusion reaction is the main reason a fission reaction is used to ignite a nuclear explosion.
Also, it could be possible for cold-fussion to be really cold-fission, or even just cold-alpha. I find more likely for coldfussioners to be able to get some cold alpha radiation, perhaps due to some solid-state effect.
With the understanding that the end result is to generate energy for consumption I don't understand why you would want to deal with alpha particles. What energy is that going to generate?
I have no idea what you just said.
neutron -> proton + electron + anti-electron-neutrino
This is very possible -- you can get deuterons this way. However, you're missing a big piece of the puzzle:
Where do we get all of those free neutrons?
The answer: we'd have to make them, investing energy. The best we could then hope to do is to get the energy back. Hydrogen (or deuteron) fusion, however, makes use of particles we already have in relative abundance -- we're just coaxing them over an activation energy hill and using the released energy.
- Warren
What is the best way to describe cold fusion as oposed to normal fusion?
chroot, I was referring to the original Fleishmann-Pons experiment. They got some helium, a bit of extra energy and some traces of gamma radiation in a very random manner. All that could fit also with an (unknown) catalisis of alpha disintegration, instead of an (unknown) catalisis of nuclear fusion.
FrankM, yep, such thing could not be useful direcly for energy production. But cheap transmutation implies a disposal method for usual radioactive waste, for instance.
Zvonko Maric
Maric was said to have a running reaction using lithium instead of deuterium.
En juin 2001 s’est tenue à Weinfeld (Suisse) une conférence internationale sur les nouvelles énergies, qui a réuni 200 scientifiques de tous horizons.
L’un des principaux intervenants, le professeur Jean-Pierre Vigier, y a exposé les travaux sur la fusion à froid, menés par le professeur Zvonko Maric, chef du département de physique de l’Université de Belgrade.
Vigier, JP: he defended cold fussion back in 1994, I bet he was influential to get F&P going into France. Vigier is a strange old man. He is DeBroglie's "scientific son". He was commisioned to develop the pilot wave theory, which he dis jointly with infamous Bohm; initially he was supossed to work in Princeton with Einstein, but he was linked -just as Bohm, or because of it?- with communism, so he was "witchhunted".
There are very used to strange physics research. Back in the fifties, they also developed Hestenes theory (yep, before Hestenes). Funny people. Anyway they are influential enough to keep publishing in refereed journals. For instance Dragic A, Maric Z, Vigier JP; Phys. Lett. A 265 (2000) 163. "New quantum mechanical tight bound states and 'cold fusion'".
As for Z. Maric, I have no ide if he is related to Mileva Maric. I have read that Mileva's family was a well-accommodated one in Zagrev.
"Cold fusion" is a contradiction in terms. It is not possible.
Cold fusion is absolutely possible. All because it is virually impossible.
  • · Replies 23 ·
  • · Replies 53 ·
12K
16K
