New Reply
Thickness of material to support a heavy load
Share Thread Thread Tools
Jun12-12, 11:36 PM   #18
So if i do not want it to bend, meaning i will calculate y as zero. I do not have the material with me and most importantly do not want it to bend while supporting the load.
Jun13-12, 12:54 AM   #19
Everything bends, even if you can't see it with the naked eye.
Jun18-12, 12:35 PM   #20
If you have a Mechanics of Solids/Mechanics of Materials book I would refer to them. The type of chapters in those books you are looking for is "Bending of Straight Beams" and "Bending of Flat Plates" or just general beam deflection/thickness theory. But from intuition alone, you are working with a 10 kg load = 22 lbs, considering a common plastic = PVC, I would say that a thickness of 5-8 mm thick depending on the other two dimensions because bending would have to be considered. Any more than 8mm would be excessive.
Jun18-12, 01:05 PM   #21
Quote by rcremont
So? PVC is generally not a cost prohibitive material...A nice thick sheet of PVC will not cost too much more than a relatively thin sheet, and you will get the benefits of both rigidity and strength.
Jun18-12, 01:29 PM   #22
@ Travis King
I wasn't considering cost because I understand that PVC is very inexpensive compared to other materials. Anything greater than 8 mm that would be not necessary. The OP wanted an exact number or range to go and purchase otherwise he/she wouldn't have posted and would have just went out and purchased a sheet themselves. Also I am assuming this is for a car or some other environment where size does matter.
New Reply
Thread Tools
Similar Threads for: Thickness of material to support a heavy load
Thread Forum Replies
material thickness required Engineering, Comp Sci, & Technology Homework 2
Material Thickness Introductory Physics Homework 5
is this too heavy a course load? Academic Guidance 8
thickness of insulation material General Engineering 1
