| New Reply |
E=mc^2 (general physics?) |
Share Thread | Thread Tools |
| Jun11-12, 05:55 AM | #1 |
Hi,
Energy is mass times lightspeed squared. Outside our earth spere there is zero gravity. Why wouldn't gravity determine lightspeed to be between 1 and 2 squared "c"? Is there a single variable for distance between the planets? This is induction, not sure what it means and what not. Is it only 'space' or something to 'overcome' between sun and earth? |
| Jun11-12, 07:21 AM | #2 |
Mentor
I'm sorry, but virtually none of that makes any sense, and what does is not correct.
| Jun11-12, 07:59 AM | #3 |
c is a constant so no. The rest of relativity is derived assuming that this is constant.
I'm confused about your thought process. Are you assuming that since the gravitational potential energy changes, that [itex]mc^2[/itex] should change? If that is the case, you are well out of the applicability of [itex]E=mc^2[/itex] which is only the energy of an object that is at rest. |
| Jun11-12, 08:31 AM | #4 |
I'm not sure.
I have no physics. I feel (not more), that c is constant but c squared, that is why I'm not certain. |
| Jun11-12, 08:57 AM | #5 |
As you can probably tell from the other posts, we're all just trying to get a handle on exactly what it is you're trying to ask. Toward that goal, I will ask several questions:
| Jun11-12, 09:29 AM | #6 |
Is there more to say about energy from the same equation? My original inspiration. Outside and nearby earth in zero gravity space. What about the object on earth and outside it. I want to reason about the object intself in different areas. |
| Jun11-12, 09:47 AM | #7 |
Ultimately I came to not understand if there is differences in space in comparison to on a planet. I do understand this now (I do not actively think so much), so energy seems be equivalent everywhere but things need more velocity on a planet,
however, does this mean particles and only with 'gravity'' there is entropy? Is there a constant for entropy? That would answer my question if positive. Namely all energy of objects(') equal? (chemistry) I get back and thought: what formula? If there is a way to reason about a single object, is entropy all the same 'relatively'? |
| Jun11-12, 10:02 PM | #8 |
Also, two objects with identical masses will require the same amount of energy to accelerate to the same speeds, irregardless of where they are located at. (Ignoring losses such as friction of course) where P is the momentum of an object. The short version of the equation without the momentum times c squared is only applicable if you want to talk about the energy of a non-moving object. Also, there is most assuredly gravity in space. Gravity is what attracts the Moon to the Earth, the Earth to the Sun, etc. (Also the Earth is attracted to the Moon, the Sun is attracted to the Earth, etc) Zero gravity is a misnomer. When you are in space you are effectively in "free fall", which causes you to have no WEIGHT. So you would be weightless. |
| New Reply |
| Thread Tools | |
Similar Threads for: E=mc^2 (general physics?)
| general physics | General Physics | 2 | ||
| How general physics differ from engineering physics | Academic Guidance | 9 | ||
| General Physics 1.... | Introductory Physics Homework | 1 | ||
