Vector Space Solutions for Systems: Explained Here
The discussion clarifies that a solution set for a system of linear equations is not generally a vector space unless it contains only the unique solution, which is the zero vector. Specifically, vector spaces must be closed under scalar multiplication, and if a scalar b (not equal to 1) is applied to a solution X, the result bX does not remain a solution unless Y is the zero vector. Therefore, the solution set of a system of homogeneous equations forms a subspace, particularly when the rank of the system is lower than the number of unknowns.
  • Understanding of linear equations and their solutions
  • Knowledge of vector spaces and their properties
  • Familiarity with scalar multiplication in vector spaces
  • Concept of subspaces in linear algebra
  • Study the properties of vector spaces in linear algebra
  • Learn about homogeneous equations and their solution sets
  • Explore the concept of subspaces and their characteristics
  • Investigate the implications of rank in systems of linear equations
Students and professionals in mathematics, particularly those studying linear algebra, as well as educators seeking to clarify concepts related to vector spaces and solution sets.
EvLer
Hi everyone,
general question: is a solution set for a particular system a vector space? I know it can be if there is a unique solution, but is it generally true?
Could someone explain, please?
Thanks.
No. Vector spaces are closed under scalar multiplication. If b is a scalar not equal to 1, Y is non-zero, and X is a solution of AX = Y, then:
A(bX) = b(AX) = bY is not equal to Y, so (bX) is not a solution, so the set of solutions is not closed under scalar multiplication, so the set of solutions is not a vector space. Perhaps I've misinterpreted your question. If there is a unique solution, then there would only be that 1 element of the vector space. The only vector space that has only one element is the degenerate vector space {0}.
For a particular system? Do you mean a system of linear equations?
The solution set of a system of homogenous equations is a subspace.
If the system consists of n independent equations in n unknowns, then it is just the 0 vector but if the rank is lower than the number of unknowns, then it is a non-trivial subspace of Rn[/sub].
  • · Replies 0 ·
9K
  • · Replies 18 ·
  • · Replies 25 ·
