Need help with EM/Jackson problem
  • Context: Graduate
  • Thread starter Thread starter pmb_phy
The discussion centers on solving problem 1.2 from J.D. Jackson's "Classical Electrodynamics - 2nd Ed." which involves demonstrating the relationship between the Dirac delta function and a Gaussian function in an orthogonal coordinate system. The key equation to prove is δ(x - x') = δ(u - u')δ(v - v')δ(w - w')UVW, utilizing the limit of the Gaussian function D(α;x,y,z) as α approaches zero. Participants emphasize the transformation of coordinates and the concept of the delta function as the inverse of a volume element, leading to the conclusion that the delta function must adjust according to the Jacobian of the transformation.
  • Understanding of the Dirac delta function and its properties
  • Familiarity with Gaussian functions and their limits
  • Knowledge of orthogonal coordinate systems and Jacobians
  • Basic principles of multivariable calculus and transformations
  • Study the properties of the Dirac delta function in various coordinate systems
  • Learn about Gaussian integrals and their applications in physics
  • Explore the concept of Jacobians in coordinate transformations
  • Review multivariable calculus techniques for handling limits and transformations
Students and professionals in physics, particularly those studying electrodynamics, as well as mathematicians interested in advanced calculus and coordinate transformations.
pmb_phy
In Classical Electrodynamics - 2nd Ed., J.D. Jackson on page 50 there is a problem I need help with. Its problem 1.2 which states
The Dirac delta function in three dimensions can be taken as the improper limit as [itex]\alpha \rightarrow 0[/itex] of the Gaussian function
[tex]D(\alpha;x,y,z) = (2\pi)^{-3/2} \alpha^{-3} exp[-\frac{1}{2\alpha^2}(x^2 + y^2 + z^2)][/tex]
Consider a general orthogonal coordinate system specified by the surfaces, u = constant, v = constant, w = constant, with length elements du/U, dv/V, dw/W in the three perpendicular directions. Show that
[itex]\delta[/itex](x - x') = [itex]\delta[/itex](u - u')[itex]\delta[/itex](v - v')[itex]\delta[/itex](w - w')UVW
by considering the limit of the above Gaussian. Note that as [itex]\alpha \rightarrow 0[/itex] only the infinitesimal length element need be used for the distance between the points in the exponent.
I can't seem to get started on this one. Note that [tex]D(\alpha;x,y,z)[/tex] is the product of three Gaussian functions i.e.
[tex]D(\alpha;x,y,z)[/tex] = G(x)G(y)G(z)
The product UVW reminds me of a Jacobian but I'm not quite sure how. :-p
Any thoughts/solutions/answers? I want to know the answer more than I want to be walked through it with hints (I have hundreds of more problems to work through besides this one which I gave up on). Thanks.
Pete
HINT:( :-p )
[tex]\iiint_{R^{3}} \lim_{\alpha\rightarrow 0} [D(\alpha;x,y,z)] \ dx \ dy \ dz[/tex]
[tex]=\iiint_{R^{3}} \lim_{\alpha\rightarrow 0} [D(\alpha;x-x',y-y',z-z')] \ d(x-x') \ d(y-y') \ d(z-z') =1[/tex]
Now make the change of coordinates...
Daniel.
Pete -- Think of a delta function as the inverse of a volume element, so if the volume at a point changes by dx dy dz -> dx dy dz/UVW, the delta function must transform as advertised.
More detail: as alpha-> zero, the Gaussian gets very narrow, and the transformation from (x,y,z) to (u,v,w) reduces to a constant one. So, the factor x*x + y*y + z*z in the original Gaussian, becomes, from dx=du/U, (u/U)**2 + (v/V)**2 + (w/W) **2. The rest is a bit of algebra.
All a delta function cares about is its own point -- the rest be damned.
Regards,
R
  • · Replies 18 ·
  • · Replies 19 ·
