New Reply
Using a DC source to generate a large magnetic field in a coil
Share Thread Thread Tools
Jun12-12, 08:48 PM   #1
I am a mechanical engineer and I'm working on a project in which I need to generate a large magnetic field in a coil of wire. The current system uses AC power (480V or 230V) and I am exploring the possibility of using a DC battery source.
The coil is has an OD of 72mm, an ID of 62mm and a height of 12mm. I need to generate around 1050 Amp-turns. I am considering using a 12V 30Ah battery.
I need help determining what components I need besides the battery. I need the electrical system to do two main things:
- release the current to the coil for a specified amount of time (< 1sec.) (timed switch?)
- reverse the direction of the current in order to change the polarity of the field (this could be a switch for each direction.
I believe I would need to have some component to dissipate the power once it has traveled through the coil, like a resistor. I'm also curious if there is certain bounds I should keep the resistance and required current within (ei. would a configuration with a coil resistance of 0.2 Ohms and requiring 70A be no good)
I appreciate any insight you can give me, let me know if something is unclear or other parameters are needed.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
>> NASA: Austin, calling Austin. 3-D pizzas to go
New Reply
Thread Tools
Similar Threads for: Using a DC source to generate a large magnetic field in a coil
Thread Forum Replies
how to generate a magnetic field General Physics 1
How can a single moving charge generate a magnetic field relativistically General Physics 34
Can Static energy generate magnetic field? General Physics 6
magnetic field coil Classical Physics 3
A coil with turns given magnetic field, time find the emf induced in the coil Introductory Physics Homework 4
