Hydraulic Pump Closing a Floodgate
  • Thread starter Thread starter Glyphstone
    Hydraulic Pump
The discussion focuses on calculating the pressure exerted by a hydraulic pump on a floodgate and determining the horsepower required for the pump. The hydraulic cylinder has a diameter of 4 inches, requiring a force of 30,000 lb to close the floodgate. The calculated pressure on the floodgate is 2287 psi, derived from the area of the gate, which is 0.087 ft². The horsepower calculation remains unresolved due to the absence of pump RPM data, highlighting the importance of pump speed in determining power requirements.
  • Understanding of hydraulic systems and principles
  • Familiarity with pressure calculations in fluid mechanics
  • Knowledge of horsepower calculations and pump efficiency
  • Basic geometry for area calculations of circular shapes
  • Research hydraulic pump horsepower calculations, focusing on RPM and flow rate
  • Study the effects of pump efficiency on system performance
  • Explore advanced hydraulic system design principles for floodgate applications
  • Learn about pressure loss in hydraulic systems and its impact on performance
Engineers, hydraulic system designers, and students studying fluid mechanics who are involved in designing or analyzing hydraulic systems for flood control applications.
Glyphstone
-4" hydraulic cylinder/piston
-closing a floodgate 4" in diameter, must exert force F=30,000lb to do so.
-Piston stroke is 2'.
-Hydraulic fluid specific gravity of 0.9.
-Pump efficiency of 0.8
Find A) the pressure on the floodgate and B) the horsepower of the pump.
Pressure = Force/Area
A) was trivial; the area of the gate is 4"=0.33ft, so Pi*r^2=0.087ft^2.
30,000lb/0.087sqft = 343,774 lb/sqft, or equivalent 2287 psi.
B) is baffling me, though, because the RPM of the pump is not given, and every equation I'm aware of for calculating horsepower requires the speed of the pump.
I assume that the cylinder is stroking in the direction to extend the rod. If not, then your area is smaller.
If they don't tell you how fast they want the gate closed, then a pump of any power rating will work. Bigger pumps will close it quicker.
  • · Replies 19 ·
10K
