How would you find the magnetic field of a spinning nucleus?
The discussion focuses on calculating the magnetic moment of a spinning nucleus and cations using quantum mechanics principles. The key formula presented is M = -μB(L + gsS)/ħ, where μB is the Bohr magneton, L is angular momentum, S is spin, and gs is the gyromagnetic ratio. This formula is validated by experiments such as the Stern-Gerlach experiment and the Zeeman effect. Additionally, the discussion highlights the use of emission spectra for identifying unknown atoms and mentions nuclear magnetic resonance as a related application.
  • Understanding of quantum mechanics principles
  • Familiarity with the concepts of angular momentum and spin
  • Knowledge of the Bohr magneton and gyromagnetic ratio
  • Basic principles of atomic emission spectra
  • Study the Stern-Gerlach experiment and its implications for quantum mechanics
  • Learn about the Zeeman effect and its role in magnetic fields
  • Explore nuclear magnetic resonance (NMR) techniques and applications
  • Investigate the derivation of angular momentum and spin values for various atoms
Students and professionals in physics, particularly those specializing in quantum mechanics, atomic physics, and magnetic resonance techniques.
Crashwinder
I'm not sure if these are very clear questions, but here goes:
1. If a fairly large nucleus is set spinning, then it should generate a small magnetic dipole, right? I'm wondering, how would you calculate it's magnetic moment, using the properties of that particular nuclide (e.g. mass, charge, etc), the speed at which it's spinning, etc?
2. Same as above, except with a cation that has a given number of electrons.
Very good question.
Quantummechanics learns us that the magnetization M is equal to [tex]\vec{M} = \frac{- \mu_{B}( \vec{L} + g_{s} \vec{S})}{\hbar}[/tex] The mu represents the Bohr-magneton, L is angular momentum and S is the spin. The g represents the gyromagnetic ratio. This formula was check experimentally via the Stern and Gerlach experiment and the Zeemann-effect for the spin quantumnumber. Now, for a given atom we can derive the possible L and S values by applying the laws of quantummechanics. This formula is especially valid for the orbiting electrons that indeed are equivalent to a magnetic dipole which yields the magnetization M. The orbit-speed is incorporated in L.
An analoguous formula can be derived for an atomic nucleus. In order to identify an unknown atom , one can excite it and then register it's emission-spectrum coming from the emitted radiation when the atom de-excites. each atom has a different emission-spectrum so this is like looking at the pass-port of an unknown atom. Many other options (using the above explained theory predicted by QM) are possible. Eg : nuclar magnetic resonance, etc
regards
marlon
marlon said:
Very good question.
Sorry for being ignorant (my understanding of this stuff is first year university level), but how exactly would you derive those?
I'm afraid i don't understand how i should apply this information, i would greatly appreciate an example or two.
  • · Replies 19 ·
  • · Replies 27 ·
