How Is Work Calculated in a Friction Scenario with Constant Velocity?
The discussion revolves around calculating work in a scenario involving friction while pushing a refrigerator at constant velocity. The original poster presents a problem where they exert a force over a distance without acceleration, raising questions about the work done by friction and the application of the work-energy theorem.
  • Exploratory, Assumption checking
  • Participants explore the relationship between applied force and friction force at constant velocity, questioning whether mass is necessary for calculations using the work-energy theorem.
Participants are actively engaging with the problem, with some suggesting the use of the work-energy theorem while others confirm that the friction force equals the applied force due to constant velocity. There is an ongoing exploration of the implications of these relationships.
There is a noted absence of mass information, which is causing uncertainty in applying the work-energy theorem. The discussion also highlights the assumption of zero acceleration due to constant velocity.
nbroyle1
You are pushing a refrigerator across the floor of your kitchen. You exert a horizontal force of
291N for 7.5s, during which time the refrigerator moves a distance of 2.7m at constant velocity.
(a) What is the total work (by all forces) done on the refrigerator?
(b) What is the work done by friction?
How can I calculate the work done by friction if a mass isn't provided and there is no acceleration obviously since there is a constant velocity?
welcome to pf!
hi nbroyle1! welcome to pf! :smile:
that's right, the acceleration is zero and the velocity is constant …
so use the work energy theorem :wink:
Thanks, but don't I need the mass for the work energy theorem also?
Net work=1/2mv(final)^2-1/2mv(initial)^2
Is the friction force equal to the force applied since it is a constant velocity? or would that just meant that the object isn't moving at all?
(try using the X2 button just above the Reply box :wink:)
in this case, 1/2mv(final)2-1/2mv(initial)2 = … ? :smile:
doesnt it just equal zero since the velocity is the same?
yes :smile:
(lots of exam questions are exactly like this)
Ok awesome thanks!
  • · Replies 16 ·
  • · Replies 58 ·
  • · Replies 25 ·
