Why do darker colors absorb heat/light?
  • Thread starter Thread starter RuroumiKenshin
The discussion centers around the question of why darker colors absorb heat and light, exploring the relationship between color, light absorption, and energy. Participants delve into the mechanics of color perception, the behavior of light with different materials, and the implications for energy absorption.
  • Some participants suggest that color is determined by the wavelengths of light that are absorbed and reflected, indicating that the question may be self-answering.
  • There is a proposal that colors correspond to specific wavelengths of light, with darker colors absorbing more wavelengths that are not reflected.
  • One participant mentions a "reverse radiometer" as an example of how different colors can absorb sunlight differently, leading to kinetic energy generation.
  • Another participant questions the efficiency of radiometers in converting light to motion, suggesting that the heating of gases within the device is a more significant factor than photon momentum transfer.
  • A participant raises a question about why leaves absorb all colors except green, indicating a curiosity about the mechanisms of photosynthesis and light absorption.
  • There is a correction regarding the specifics of chlorophyll absorption, with a focus on the wavelengths involved in the photosynthetic process, although this correction does not resolve the broader question of color and heat absorption.
Participants express various viewpoints on the relationship between color, light absorption, and energy, with no clear consensus reached on the mechanisms involved or the implications of these relationships.
Some claims about the efficiency of energy conversion in radiometers and the specifics of chlorophyll absorption are made, but these remain unresolved and depend on further clarification of underlying principles.
RuroumiKenshin
Biology news on Phys.org
The question needs minor re-phrasing. You see, the fact that something is a certain color is caused by it's absorbing certain wave-lengths of light (not the other way around).
More minor clarification: The color is caused by BOTH what is absorbed and what is reflected (for opaque objects).
So the question is self-answering.
Now that the question has been re-phrased, perhaps someone would like to answer it?
Oh, OK...i'll do it...
What they mean Majin, is that our experience of colour occurs because only particular light wavelengths of the spectrum are reflected. The wavelengths which are reflected are what we see, and the wavelengths which are absorbed are the colours we do not see.
So a green leaf, is actually absorbing all of the colours which are not green (to oversimplify...)
As for colours absorbing heat. I ahve never heard that as such. Colours = Light though, and light = energy, and energy = heat... maybe there is some sort of connection there.
Have you ever seen a "reverse radiometer"? (At least I think that's what it's called.) I saw it on the deleted scene of "The Time Machine". It looked a lot like a wind-mill, but moved by the energy of the sun, as opposed to the energy of wind. You see, it's fins were colored white on one side, and black on the other side, and thus only one side of each fin was absorbing the sun-light, while the other side reflected it. This translated to kinetic energy, and the "reverse radiometer" began to spin.
Yeah, the connection is the one you made. By the commutative property of math, light = heat (more or less). Every color corresponds to a specific temperature.
You mean you DIDN'T have one in your high school physics lab? Wtf?!
If you hold up a vial of chlorophyl dissolved in alcohol, its reflected light (light behind you) appears green, but its transmitted light (light behind vial) appears red! The differences between frequencies times Planck's constant must be close to the reaction energy of ATP<-->ADP?
Most radiometers are not sensitive enough to turn primarily by photon momentum transfer. Rather, the black and white sides of the fins heat up differentially the rarified gas present within the radiometer and cause motion with the white side leading. Photons, I think, would cause rotation in the opposite direction. Not an efficient way to generate large amounts of energy here on Earth.
ermz ..so why do leaves absord all the other colours except for green?
Actually, that's not correct. The reaction centers in chloroplasts absorb two photons, at 680 and 720 nanometers. This is used to reduce water, shunt protons across a membrane, and reduce NADP+. The protons go on to produce ATP, and the NADPH drives the Kreb's cycle, which produces sugars, which can be oxidized to produce ATP. But it's a far, far way from being a 100% effecient system.
  • · Replies 16 ·
24K
