New Reply
Binders in SSP fertilizer
Share Thread Thread Tools
Jun15-12, 02:43 AM   #1
Dear Forum
I am a junior engineer newly appointed by a fertilizer production company. I have been given the assignment to improve the SSP granule hardness and storage characteristics. Currently the granules are too soft and the drying time prior to bagging is also long. I am considering adding a binding agent to the fertilizer. I have considered sodium silicate, potassium silicate, lignosulfonates or bentonite clay as possible agents. However I am having considerable trouble finding reliable information regarding the use of these agents and the application methods. For example I am worried that if I should use sodium silicate, the granules' water solubility would be lowered considerably after drying in the drier. The fertilizer powder is granulated using drum granulators and water. Any advice or information is sincerely appreciated.
Regards
Rommie
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Jun23-12, 10:12 PM   #2
I am sure you will find literature from bentonite producers, and it can be added as a slurry to bind or act as a final coat. It should also become somewhat hydrophobic if a small amount of biodegradable surfactant is used in formulating. Look in patent literature with appropriate boolean search terms.
I would steer clear of silicates as they could render any micronutrients as insoluble rock. Also silicates can be hard to dry compared to clays.
Jul2-12, 09:10 AM   #3
Hi
Thank you for the advice!I have started to research bentonite clay. According to the plant manager it cannot be added in slurry form, he didn't explain why though, I'm assuming the clay might neutralize the acid in the slurry and influence the reactions. I am not sure whether adding it in a powder form to the powdered fertilizer and then granulating it using water would have any notable increases in granule strength. I am still searching for information and will post as soon as I have something that may be of interest.
Regards
Rommie
Jul2-12, 06:31 PM   #4
I can understand if the reactor is a tube or other reactor than a tank; plugging with clay would be very bad indeed.... I thought however, that the fertilizer xtal slurry might be able to withstand the introduction of a clay slurry that is very dilute and held suspended with surfactant. The lines that feed the slurry would always have to be moving or plugging would be a problem due to the thixotropic effects of bentonite slurries.
If you are using a spray drier, the bentonite could be suspended in the drying air and may coat the prills and produce some of the results- I suspect it will also cause a lot of extra downtime chipping away coated walls... !>)
New Reply
Thread Tools
Similar Threads for: Binders in SSP fertilizer
Thread Forum Replies
Solubility of a Fertilizer Biology, Chemistry & Other Homework 1
How do you fix 3 ring binders General Discussion 9
Inorganic Fertilizer Chemistry 1
