Transformation for accelerating observers
The discussion revolves around the transformation of coordinates between two accelerating observers, A and B, who are moving relative to each other at a uniform velocity. The participants explore whether the Lorentz transformation applies in this scenario, considering the complexities introduced by acceleration and relative motion.
  • Some participants propose that the Lorentz transformation can be applied since A and B are moving relative to each other at uniform velocity, regardless of their acceleration with respect to a third inertial frame.
  • Others argue that the situation is more complex, referencing the Bell Spaceship Paradox and suggesting that the ambiguities in terms like "accelerating at the same rate" and "coordinates of an event" could lead to different answers depending on how the scenario is specified.
  • A participant highlights the importance of Rindler coordinates and the Rindler horizon, indicating that these concepts introduce additional subtleties to the discussion.
  • Mathematical transformations between uniformly accelerating observers and inertial observers are presented, showing the complexity of deriving coordinates in such scenarios.
Participants do not reach a consensus on whether the Lorentz transformation is applicable in this context. Multiple competing views remain, with some supporting its use and others questioning its validity based on the complexities of acceleration and relative motion.
Participants note ambiguities in key terms and concepts, such as "accelerating at the same rate" and "moving relative to one another at uniform velocity," which affect the clarity of the discussion. The mathematical steps involved in transformations are also presented without resolution.
ralqs
Suppose two observers A and B are each accelerating at the same rate wrt an inertial reference frame, but are moving relative to one another at some uniform velocity. Will the transformation between the coordinates of an event as measured by A and B be the Lorentz transformation?
I'd say yes, since it doesn't matter that A and B are accelerating wrt to a third frame of reference. The key is that they are moving relative to each other at uniform velocity and you're using the lorentz transformation between them.
It's not that simple. Check out the Bell Spaceship Paradox:
http://en.wikipedia.org/wiki/Bell's_spaceship_paradox
http://math.ucr.edu/home/baez/physics/Relativity/SR/spaceship_puzzle.html
In addition to the Bell Spaceship Paradox, it's also good to check out Rindler coordinates and the Rindler horizon:
http://en.wikipedia.org/wiki/Rindler_coordinates
http://gregegan.customer.netspace.net.au/SCIENCE/Rindler/RindlerHorizon.html
As the above links should show you, there are a number of subtleties lurking in the question you've posed. One is that the term "accelerating at the same rate" is ambiguous. Another is that "the coordinates of an event as measured by A and B" is also ambiguous. So the answer to your question could be "yes" or "no" depending on how you choose to tighten up the specifications of your scenario to resolve the ambiguities. I suspect that the answer to the question you were trying to ask, once the ambiguities are resolved, is "no".
Edit: I should mention that "moving relative to one another at uniform velocity" is also ambiguous in this scenario. :wink:
The transformation between uniformly accelerating and inertial observers is given here:
If you start with an observer "at rest" in the accelerating frame you have a world line[tex](t,x,y,z)=(t,x_0,0,0)[/tex]
Transforming that to the inertial coordinates you get: [tex](T,X,Y,Z)=(x_0 \sinh(g t), x_0 \cosh(g t),0,0)[/tex]
So a similarly accelerating observer, but with different initial velocity will have the worldline: [tex](T,X,Y,Z)=(x_0 \sinh(g t), x_0 \cosh(g t)+v_0 t,0,0)[/tex]
Transforming this back to the accelerating frame gives: [tex](t,x,y,z)=\left( \frac{1}{g} atan\left( \frac{x_0 \sinh(g t)}{v_0 t+x_0 \cosh(g t)} \right),\sqrt{v_0^2 t^2+x_0^2+2v_0 x_0 t \cosh(g t)},0,0\right)[/tex]
  • · Replies 101 ·
  • · Replies 34 ·
  • · Replies 40 ·
