New Reply
Force... What is energy's role?
Share Thread Thread Tools
Jun16-12, 05:08 PM   #1
Hallo,
When force is acted upon a certain object it could change its direction,movement. Does force require energy to be produced?
Looking at all the natural forces they seem to be created and force comes along with them. If force can move an object or stop an object or ever accelerate one. What is energy's role in all of them? Is it like this example:
Magnetic fields producing a natural force that can only be triggered by energy, same as gravity.
Are natural force only triggered by energy?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Soft matter offers new ways to study how ordered materials arrange themselves
>> Making quantum encryption practical
Jun16-12, 06:29 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by Momento View Post
Hallo,
The short answer is no, but it is kind of a complicated question.
I think you have a misunderstanding of what energy is. Energy is simply the ability for one system to perform work on another. Energy does not cause things to happen, that is the result of forces.
Jun16-12, 07:57 PM   #3
Recognitions:
Homework Helper Homework Help
The key word is could. If it does not in fact change anything, no work has been done. Work = force * distance through which the force produced movement of the point of application, in the direction of the force.
Jun17-12, 04:32 AM   #4
Quote by Drakkith View Post
If force is produced over a distance is there energy being stored/converted...?
Quote by haruspex View Post
So force is crucial for a system to do work right?
Jun17-12, 05:32 AM   #5
Recognitions:
In as far as it's included in the definition, you can't have one without the other.
If the car's not in gear (to transmit a force), the engine can't do any work in getting it moving.
Jun17-12, 04:38 PM   #6
Recognitions:
That doesn't logically follow. I stated how a force does work. Perhaps things other than forces can do work. Heat flow, e.g.
Jun17-12, 04:42 PM   #7
Recognitions:
Nope. 'Work' is a strictly defined quantity, involving force and displacement. You are trying to associate work with energy in general, which is not precise.
Jun17-12, 05:03 PM   #8
Recognitions:
Quote by sophiecentaur View Post
That's not universal. Many authorities distinguish between mechanical work, electrical work, chemical work and thermodynamic work (heat).
Jun17-12, 05:11 PM   #9
Recognitions:
That's not how I am used to it. Do you have a reference to these other uses of the word? There seems little point in expanding its meaning so that it becomes synonymous with 'Energy' or 'Potential'.
I do know that 'work function' is used in respect of the energy required to remove photo-electrons but even that involves a mechanical idea, albeit small scale. (And it is a fairly ancient concept along with Electro Motive Force)
Jun17-12, 05:17 PM   #10
I am far from an authority, but I have never heard heat referred to as thermodynamic work. In fact, the two are strictly different according to the first law of thermodynamics. Electrical work is the work done on a charged particle by the electric field. A charged particle feels a force in an electric field.
These specific cases of work can be distinguished, but the definition of work requires a force. If you don't explicitly define a force, it follows from the definition that [itex]-\frac{dW}{dr}=F[/itex].
I would be surprised to see work used in a situation where a force could not be easily defined unless the author was explicitly being loose with definitions.
Jun17-12, 05:46 PM   #11
Recognitions:
It's not so much a matter of expanding the meaning. It's more that the meaning of the word "work" has tended to contract to cover only mechanical work in most usage. It's a bit like the use of "forensic" to mean specifically forensic science. It really means "pertaining to law".
Early statements of the laws of thermodynamics included "heat is work and work is heat". The term energy was not so widespread.
But I was wrong to say thermodynamic work meant heat - it's everything except heat. For the rest, see http://en.wikipedia.org/wiki/Work_%28thermodynamics%29.
Jun18-12, 08:29 AM   #12
Ok, Some of you are realting work to energy and I doubt their the same. I'm kinda confused and stuck in the middle here...
All I know now is a system that is able to work will always require "Force" to do so. In many system their are countless forces that have to come into account. Some forces are already being generated from a system's energy and other may have forces upon them such as you and I and all objects that have gravitational force on them.
"sophiecentaur" has a good point about the matter so far.
Jun18-12, 08:33 AM   #13
But isn't heat energy from its origins? I mean heat is the act of atoms having a lot of movement isn't it, so thats energy right?
Jun18-12, 12:24 PM   #14
Heat and work are exchange of energy.
Jun18-12, 04:30 PM   #15
Recognitions:
If you only consider work to cover mechanical work then, yes, force will be required.
The references I've found show that 'work' nowadays means any form of energy other than heat, and that if you care about the specific form of work then you should qualify it as mechanical, chemical, electrical, and so on.
For some of these it is not so clear that there would always be a force involved in transfer. Is there a force involved when a photon excites an electron in an atom? Maybe.
Jun18-12, 05:07 PM   #16
Recognitions:
The interaction by which any transfer of energy takes place is the result of a force. Without a force there would be no interaction between two particles and no energy would be exchanged.
Jun18-12, 05:45 PM   #17
I would say force is a result of interaction not the other way around.
New Reply
Thread Tools
Similar Threads for: Force... What is energy's role?
Thread Forum Replies
Explaining role of Pions in Strong force interactions. High Energy, Nuclear, Particle Physics 6
Friction forces playing the role of centripetal force Classical Physics 2
force in kinetic energy/force in momentum =1 Introductory Physics Homework 2
The role of gravity in terms of work done by an angled force on an incline Introductory Physics Homework 4
role of the engineer Engineering, Comp Sci, & Technology Homework 3
