| New Reply |
Help understanding x,y,z equations |
Share Thread | Thread Tools |
| Jun17-12, 01:23 PM | #1 |
I have a point at 0,0,0(the origin).
And I have an object that will move around that point. The following data is given for that object: r = 5 theta=4 phi=6 phi is the angle that is between y and z. theta is(probably) between y and z. To find the object coordinates(x,y,z),the following equations are given: y = r * cos(phi) x = r * sin(phi) * sin(theta) z = -r * sin(phi) * cos (theta) we use -r on z because theta is measured counterclockwise from -z. As you can see the equations above make an object stay at some certain coordinates away from the origin. Everything is solved,the only problem is that I don't understand it. I understand how we get y,but the x and z are sci fi for me,I mean why does x use sin on both phi and theta and z uses sin and cos? Take it easy on me,I suck at math,and in the last 3 days I've been trying to understand those equations.If you know why everything is like that,please explain with as many details as you can,so I can finally understand and sleep... |
| Jun17-12, 04:18 PM | #2 |
[itex]\phi[/itex] is the angle between the object's position and the y-axis. We decompose the position vector into a part parallel to the y-axis and a part perpendicular, which must then lie in the zx-plane.
Considering just that last part--the part of the position vector that lies in the zx-plane--and find the angle that makes with the -z-axis. This is the angle [itex]\theta[/itex]. Everything in this procedure is just about drawing right triangles, see? |
| New Reply |
| Thread Tools | |
Similar Threads for: Help understanding x,y,z equations
| need help with understanding synthesis equations | Biology, Chemistry & Other Homework | 1 | ||
| Understanding Equations | General Physics | 10 | ||
| Understanding the kinematic equations | Classical Physics | 7 | ||
| question in understanding differitial equations.. | Differential Equations | 14 | ||
| Need help understanding work equations :-) | General Physics | 9 | ||
