Length contraction of falling things
The discussion revolves around the concept of length contraction as observed from the Moon, specifically regarding a falling brick and a falling light pulse. Participants explore the implications of special relativity (SR) and general relativity (GR) in understanding these phenomena, with a focus on the complexities introduced by gravitational fields.
  • Some participants propose that an observer on the Moon would see a falling brick contract, while the situation with a falling light pulse is more complex.
  • One participant suggests that the contraction of the light pulse is proportional to blue shift, claiming that the front of the light pulse moves slower than the rear due to gravitational effects on light.
  • Another participant challenges this view, asserting that the explanation provided is incorrect and that the contraction does not occur as described.
  • A later reply emphasizes the importance of understanding simultaneity in general relativity when measuring lengths in a gravitational field.
  • One participant shares a thought experiment involving measuring light pulses at different altitudes and speculates that boxes containing light from lower altitudes would be smaller and contain light with more energy.
  • Another participant argues that a meter stick or box filled with radiation would not change its length when raised or lowered in a gravitational field, suggesting that local physics remains consistent.
  • There is a mention of the speed of light being affected by gravitational potential, referencing Shapiro's time delay and the implications for measuring light speed in different gravitational contexts.
Participants express differing views on the nature of length contraction in gravitational fields, particularly regarding light pulses. There is no consensus on the explanations provided, and multiple competing perspectives remain throughout the discussion.
Participants note that the definitions of terms and the assumptions made about simultaneity and gravitational effects are crucial to the discussion, highlighting the complexity of the topic.
jartsa
1: Does an observer, standing on the moon, see a brick, that is falling straight down, to contract?
2: Does an observer, standing on the moon, see a light pulse, that is falling straight down, to contract?
Yes.
The answer to this question is much more complicated, the detailed mathematical explanation can be found here, I just posted it a few days ago.
Oh yes, the contraction is proportional to blue shift. And the simplest blue shift case is very simple.
Here's something people here may disagree with:
The contraction happens because the font of the light pulse moves slower than the rear of the light pulse. And that happens because light slows down in a gravity field.
I don't know where you get this but it is wrong.
You are making up stuff.
What's your motivation for asking the question?
If you're trying to understand SR better, dragging GR into it isn't really a good way to proceed. You're much better off handling the simpler case in flat space-time where there's no gravity to confuse the issue.
If you're trying to understand GR better, it would be a good idea to sketch exactly how you propose to measure the length of the object remotely. I can warn you in advance that the notion of "distance" in general relativity is ambiguous, mainly due to differing notions of simultaneity. Some people understand the warning, some don't, and I get a bit frustrated trying to explain the problem to those who don't. This is really a SR issue, by the way, but it's an important one to understand before you try to tackle GR.
I can tell you how in general I would go about "setting up" the problem. The first step is to decide what notion of simultaneity you want to use, and why. So I would start by assuming that the moon is the most significant gravitating body, and that we can ignore the Earth. Right away, I can see a possible conflict with your question, perhaps you didn't intend the moon to be the most significant gravitating body? In that case, the issue of how to determine the notion of simultaneity would require some thought. If the moon is the most significant source of gravity, however, there is an obvious way to proceed, that is to use a clock synchronization scheme compatible with "static observers". It's less obvious how to proceed if the moon is not the most significant source of gravity.
Once you have decided on the notion of simultaneity you're going to use, the simplest procedure is to construct a spatial geodesic curve. (Not a space-time geodesic, but a spatial geodesic!). Constructing this geodesic will require you to use the metric induced on your spatial hypersurface by your space-time geometry. Constructing the geodesic will require some knowledge of the geodesic equations, and how to solve them. Solving them directly is usually difficult, and taking advantage of conserved quantities via means of Killing Vectors or some equivalent procedure, is highly recommended.
Next you need to confirm that the problem that you've set up is really one-dimensional. If it is, then you mark on this spatial geodesic curve the position of the front end of the rod, and another mark for the rear end of the rod, "at the same time", according to your notion of simultaneity. If both ends of the object aren't on a single curve, then your problem isn't one dimensional. But let's assume that it is. Then the length along the curve (the spatial geodesic) between the marks on the front and rear will be the "length of the rod".
I'm afraid I can't give an exact formula for the result you'd get if you followed this procedure, I'd actually have to work it. My own view is that the exercise of thinking about what you want to measure is considerably more helpful than going through the detailed calculations of calculating the number. Furthermore, if you don't understand what all the steps I've outlined mean (and some of them might require a certain amount of expertise), just giving you the number won't really accomplish much.
I could use some new facts in my thought experiment building hobby.
Let's say the light pulse is catched into a box which is just large enough. This is done at many different altitudes, with many light pulses.
Then all boxes are moved into same place and compared.
I would guess the boxes from lower altitudes are smaller, and light in these boxes has more energy.
If you raise or lower a meter stick, oriented normally to the gravitational force so the change in stress doesn't cause the length to vary, I can't see any reason for it to change it's length.
So I would say that the same applies to a box, say a microwave cavity filled with one wavelength of microwave radiation. The local physics will be the same, the cavity/box won't change length, and a local frequency counter would measure the same frequency, the constant length of the cavity divided by c, no matter what the height of the box was.
The energy-at-infinity would change as you raised the box, but I think this could eventually be traced back to the work done in raising the radiation in the box. It will take more work to raise a box full of microwave radiation than one that's empty. I'm not aware of ay formal p roof of the matter, but I don't see how it could be otherwise.
jartsa said:
[..] Here's something people here may disagree with:
People can disagree with anything - and often it very much depends on definitions of words. :-p
But it's a simple fact that if according to a distant observer a stationary meter rod is length contracted and a clock at one end is ticking slower, that then with that reference system the return speed of light can only be measured as c if the light according to the distant observer is slowed down with gamma squared (using a standard and consistent meaning of words).
PS: As Shapiro's phrased it, "the speed of a light wave depends on the strength of the gravitational potential along its path" - http://prl.aps.org/pdf/PRL/v13/i26/p789_1 .
See also discussions on "Shapiro time delay" and note that according to GR the rod will not be contracted if held parallel to the surface.
Similarly to your misconception about clocks slowing down, in GR light (in vacuum) also does not ever slow down in a coordinate independent sense. It always travels along null geodesics.
Even in flat spacetime, it is possible to write down coordinates in which the coordinate speed of light is faster or slower than c, but these are obviously coordinate-dependent statements. Anywhere in any spacetime that you find a set of coordinates where light slows down there are also other sets of coordinates where it does not.
Agree entirely with that observation. And it agrees I believe with what #10 was intending to convey. One just needs to be careful in defining precisely the relative nature of 'length change' in such situations.
In SC's transverse length in coordinate measure expressly is invariant wrt potential, but not if that rod is radially oriented (and that's with 'stress' subtracted out). But 'radially shortened' is imo only of value in the sense that integrating over an extended radial path r2 to r1 (coordinate measured), there is more proper distance covered in the interval r2-r1 than if gravity were switched off. We all agree that locally no length or time distortions can logically be evident.
Which is distinctly different to OP's scenario - free-falling light pulse measured at different heights by a 'hovering ruler' (the box in effect).
Sure, and that gets back to arguments I was making elsewhere re 'charged BH' and elsewhere - EM field energy associated with charges/currents of a non-free-fall system, is depressed in a gravitational potential by redshift factor. Not so for geodesic propagating light beam.
Size yes, but energy I don't know - that's a tricky topic. My guess would be that the total energy doesn't change.
Even in "thought" experiments, you cannot just ignore basic facts of physics. You cannot "catch" light in a box and move it.
Well, then I guess I must be saying things in a coordinate dependent sense. Is that a bad thing?
Well of cource it changes. Light that falls, and bounces back, does not change. Light that falls, and is lifted back, does change.
No, it isn't a bad thing as long as you understand what you are doing and are clear about it. Otherwise it leads to confusion, which I believe is reflected in your writing.
My guess would be the same as harrylin's. I don't think that the "of course" is warranted, unless you have a completely foolproof derivation in three lines or less.
It is possible to say things correctly in a coordinate dependent manner, just difficult. For instance, you need for starters to specify what coordinates what you're saying is valid in. This usually leads to rather long explanations. Coordinate independent explanations don't need all the background, so they can usually be much shorter.
So, if you don't like writing a lot, and in great detail, it's a big advantage to talk in coordinate independent terms. It's also easier (for the most part) for the reader to follow.
Of course, it's also possible to say things in a coordinate dependent manner that are just plain wrong. (It's possible to say wrong things in a coordinate independent manner too, of course).
I'll use an example I've used before of saying something that's just plain wrong. Suppose you're talking about length contraction, in the context of the surface of the Earth, and you start saying that "distances are smaller near the poles". Hopefully, it's obvious that this is just plain wrong.
But let's examine what you might be thinking, a related concept that isn't wrong.
Now, you might be thinking in a coordinate dependent manner, and what you are really trying to say is that one arc second of longitude near the equator is longer than one arc second of longitude near the poles. This would be correct, unlike saying that "distances are shorter near the poles".
The fundamental mistake that was made here is conflating (confusing and combining) differences in coordinates, i.e. changes in lattitude, and distances. The two concepts are different. The first concept is not a distance. You can, however convert it to a distance by using the local metric coefficients. After you've performed the appropriate connection, it becomes a distance.
I often see the same type of error made in relativity, in relation to the Schwarzschild R coordinate. Conceptually, it's a coordinate, not a distance. It doesn't become a distance until you apply the metric to it.
It isn't really coordinate dependent, however it's "reference frame" dependent. And while some people seem to think that that's a bad thing, others don't. For example, many physicists don't think that it's a bad thing to talk about "high energy" electrons. Of course, in such cases the reference is clearly implied.
A material object "falls" by accelerating towards the gravitating body, and in that process we can imagine that potential energy is transformed into kinetic energy. I think that the total energy of such a two body system in isolation must remain constant, as determined with a non-local reference inertial system. In contrast, and as you suggested yourself, light that propagates directly towards the gravitating body does not accelerate towards it but decelerates; moreover it looks to me that it has only kinetic energy which should remain constant from that perspective as long as the box is not moved (I could be wrong there, but for sure its frequency is unchanged). Next, moving the box demands more analysis.
So, in view of those points, please elaborate your thought experiment - which, it seems, has little to do with your topic. :-p
We can drop light into a box, lift the box, take light out, move box back down, drop the light into the box, lift the box ... energy is used, it must go somewhere, the light is the only alternative.
UNLESS light is weightless. If light is weightless form of energy, we can very easily build a perpetual motion machine. So it's not weightless.
Let's define weight as exchange of momentum with a gravitating object. We probably agree that light bends in a gravity field, and momentum change happens when light bends.
What happens to light that moves straight up or straight down ... that's an interesting question.
I think you mean some basic facts from which to draw conclusions and make thought experiments?
A few to get started:
[1] All local clocks [of good quality] tick at the same rate. A clock here and a clock there tick at the same rate, but neither may appear to do so to a DISTANT observer. Another way to say this is that clocks record proper time, and that is not dependent on the coordinates used, nor the path you take. Any clock you carry with you records your local age and local processes along your worldline...your path through space and time. In GR, clocks don't slow down in any coordinate-independent sense; they measure proper time along their worldline, your worldline if you are carrying the clock, which is an invariant quantity. [2] The local speed of light is always c. This means light always travels at the same speed 'c' right where you are. The speed of light as observed in curved spacetime varies, that's general relativity, but right where you are [locally] spacetime is flat and light is always observed at speed 'c'. This seems somewhat 'crazy' at first because no matter your speed relative to anything else, light still zips by you at the constant 'c'. That idea takes a while to get used to.
In special relativity, meaning flat spacetime, all inertial observers see light at speed 'c'. This means distant and local observers. But for accelerating observers, things change... observations vary.
Jartsa:
UNLESS light is weightless. If light is weightless form of energy, we can very easily build a perpetual motion machine. So it's not weightless. Let's define weight as exchange of momentum with a gravitating object. We probably agree that light bends in a gravity field, and momentum change happens when light bends. What happens to light that moves straight up or straight down ... that's an interesting question.
WHOAAA! You have way too much stuff going on...ambiguous terminology...too many conflicting ideas with erroneous statements and conclusions...slow down, dude! seems like ideas pop into your head and you write them down...instead, take ONE idea and give it some thought as to the consequences of what you are posting ...
First off; light has no mass...but you cannot willy nilly draw conclusions from that such as 'no mass [no weight] so no work' with your box questions ...and 'no mass' does NOT mean because it is 'weightless' you can build a perpetual motion machine...that's mostly gibberish. [Energy is equivalent to mass via E =mc2 and light has energy; this means it is gravitationally attractive like everything else we know.]
So before we talk about light in boxes going up and down let's look at a few basics:
[These have been fully discussed elsewhere in these forums, so if I can remember them, they'll be correct and maybe we can even find all the detailed discussions if required]Let's say a bunch of observers have identical light sources...all have the same reference color [frequency]. A series of local observers at different gravitational potentials, say at fixed distances in a uniform gravitational field, would each subsequently observe a photon passing their own location to have different red shift [different energy, different color] relative to a local reference photon. Each measures velocity 'c'. [from my post above]
This means the kinetic energy of observed photons has changed...such KE increases as gravitational potential decreases. Light further down becomes blue shifted.
[Different coordinate perspective: From the viewpoint of a free falling observer at rest in the freely falling frame, there is no "gravitational field". She is weightless, feeling no force, so to her, local physics looks the same as in free space with no gravity. Photons in free space with no gravity do not redshift. So the motion of the observer is critical to what KE they measure.]Another example: Suppose a flashlight shines down into a deep gravitational well with a lead shield at the bottom: could it penetrate the lead shield?
Answer is yes: The light picks up kinetic energy [is blueshifted] and loses potential energy as it falls: that means a flashlight beam becomes like gammas rays [lots more KE if the gravitational potential is strong enough]. So in theory it can punch thru the shield.
I think this is also accurate: Another view: If you move a lead shield rapidly enough against a flashlight beam, the beam can also in theory punch through that shield: the shield 'sees' the light as extremely energetic...really short frequency...these views are equivalent...Ok: so what do you conclude will be the characteristic of such light 'boxed' by different observers. Right where they make the observation. Then maybe we can figure what happens when the light is removed outof the gravity well??
Naty1 said:
J[..]
[..] The light picks up kinetic energy [is blueshifted] and loses potential energy as it falls: that means a flashlight beam becomes like gammas rays [lots more KE if the gravitational potential is strong enough]. [..]
Hmm I also remember them, and according to me the consensus in the scientific literature is contrary to what you say - and I also disagree with your conclusions.
According to you, if you change your perspective, is it then accurate to say that kinetic energy "changes"? I think that that is misleading. Moreover, according to GR reference clocks at lower gravitational potential tick slower (that is, as observed with a stationary non-local reference system). Einstein predicted the redshift effect based on that conclusion. Your blueshift would be double the predicted and verified amount if you were right. In other words, your presentation denies gravitational time dilation. If you like, I can dig up a good physics paper about that (I think it was by Okun).
Same characteristic. Light does not change when catched into a box.
Sure it does, it either becomes a standing wave or becomes absorbed. It is no longer a wave in vacuum, but is interacting with matter. The equations that govern light's behavior change substantially. Have you ever done any actual EM?
jartsa, I agree strongly with Naty1's comments of post 25. You make such a slew of errors, strange assumptions, confused reasoning, and unsubstantiated assertions that it is hard to even know where to help you. You are just "all over the map", please slow down. Which one topic are you most interested in:
1) length contraction in gravity
2) speed of light in GR
3) coordinate dependence/independence
4) light in a box
5) something else ...
Originally Posted by Naty1
J[..]
Austin0 said:
In one view the difference in observed frequency is purely due to the dilation differential between the electrons of emission and reception.The photon retains its initial frequency throughout . There is no change in the photon during transit.
The other view is that the photon does change in transit. Gaining momentum into the well and comparably loosing it going uphill.
. Gravitational time dilation itself, is now a fact. SO this explanation totally accounts for the results. I.e. A difference in resonant frequencies of emitting and absorbing electrons due to dilation.
so the assumption of any additional factor at work would seem to necessitate additional observed end results above the gamma factor or be rejected.
DaleSpam said:
There is no need for all sorts of mental gymnastics or contorted logic here. It is just a simple and clear experimental result (that light's energy is affected by gravity just like everything else's energy) and the usual understanding that energy is frame variant.
Coincidentally this same question came up in another recent thread where I expressed this same view as yourself, but it is seemingly not generally accepted by those here. ;-)
  • · Replies 64 ·
  • · Replies 78 ·
  • · Replies 63 ·
  • · Replies 45 ·
  • · Replies 54 ·
