New On-line Cosmology Calculator
  • Context: Undergrad
  • Thread starter Thread starter marcus
    Calculator Cosmology
The discussion centers on the "cosmology calculator," an online tool maintained by a University of Iowa astronomy professor, which allows users to calculate various cosmological parameters based on redshift values. To achieve mainstream consensus results, users should set the Hubble parameter to 70, the matter density ("omega") to 0.27, and the cosmological constant ("lambda") to 0.73. The calculator provides outputs for the distance of astronomical objects when they emitted light, their current distance, and their recession speed. A rule of thumb for estimating recession speeds is provided, indicating that for redshift values between 1.5 and 6, users can add one to the redshift and multiply by 0.4 to approximate the recession speed as a multiple of the speed of light.
  • Understanding of redshift and its significance in cosmology
  • Familiarity with the Hubble parameter and its role in cosmological calculations
  • Knowledge of matter density ("omega") and cosmological constant ("lambda")
  • Basic grasp of recession velocity and its implications in astronomy
  • Explore the "cosmology calculator" at http://www.earth.uni.edu/~morgan/ajjar/Cosmology/cosmos.html
  • Read the paper "Superluminal Recession Velocities" by Davis and Lineweaver for deeper insights
  • Investigate the implications of redshift on the observable universe
  • Learn about the significance of the Hubble constant in modern cosmology
Astronomy students, astrophysicists, and anyone interested in understanding cosmological calculations and the behavior of distant celestial objects.
marcus
Dearly Missed
An astronomy prof who teaches at a University in Iowa
maintains a resource page of online astro java applets
for students and general public to use
and one of the applets is "cosmology calculator"
Here is her homepage
http://www.earth.uni.edu/smm.html
If you try out the "cosmology calculator" and want it to give mainstream consensus answers similar to Ned Wright's and so on, then leave the Hubble parameter 70 (the default)
and put 0.27 in for the matter density ("omega")
and put 0.73 in for the cosmo. const. ("lambda")
Then every time you put in a redshift z (like z = 6.4 for a recently observed quasar) and press "calculate" it will tell you
how far away the thing was when it emitted the light we are now receiving from it
how far away it is now
how fast it was receding from us when it emitted the light we are now receiving
Astronomy news on Phys.org
A nifty rule of thumb for recession speeds
For z in the range 1.5 to 6, good rule of thumb for recession speeds is this:
this will give the speed that the thing was receding
at the moment it emitted the light that we are seeing
and it will give the ("then") recession speed as a
multiple of c.
So redshift 1.7 implies 1+z = 2.7 implies it was receding at just over the speed of light
And redshift 5 implies 1+z = 6 implies it was receding at 2.4 times speed of light
This is an approximate, not exact, rule. It seems accurate to two significant digits which often gives a good enough idea, and saves having to use one of the online calculators or (godforbid) do an integral.
So that quasar observed in 2002 with z = 6.4 was retreating at almost 3 c when it sent us its light.
It might occur to someone to ask how it happens that the light ever got here. It must have begun its journey by actually losing ground to the Hubble flow and being swept back away from us---how can it eventually arrived here? Davis and Lineweaver discuss this in an explanatory paper "Superluminal Recession Velocities" that I believe you can find by google as well as by the arxiv search function.
  • · Replies 37 ·
  • · Replies 23 ·
  • · Replies 55 ·
11K
  • · Replies 23 ·
