MATLAB: Confusing Contour and Color Scale Map Results
  • Context: MATLAB
  • Thread starter Thread starter nenyan
    Confusing Matlab
The discussion revolves around the differences observed when using MATLAB to create contour and color scale maps from an array. Participants explore issues related to data representation and visualization techniques in MATLAB, including the use of functions like contour, image, and imagesc.
  • One participant notes that the results from using the contour and image functions are very different, suggesting a potential issue with how the data is being interpreted.
  • Another participant speculates that MATLAB's image function may be treating the matrix as levels in the range of 0-255 or 63535, which could lead to indistinguishable values if they are too small.
  • A suggestion is made to normalize the data to address the issue, although a later reply indicates that normalization did not resolve the differences.
  • One participant identifies that the y-axis is reversed, which may contribute to the confusion in the visual output.
  • Another participant recommends using the imagesc() function as an alternative, stating that it automatically adjusts the scale range to fit the data.
Participants express differing views on the causes of the discrepancies in the visual outputs, with no consensus reached on a single solution. Some propose normalization while others suggest using imagesc(), and one participant identifies the issue of the reversed y-axis.
Participants have not fully explored the implications of using different functions or the specific characteristics of the data being visualized, leaving some assumptions and conditions unaddressed.
nenyan
When I use MATLAB to draw contour and color scale map of an array. The result is weird.
my code:
the first:
b=load('c:\...\b.txt');
contour(b)
the second:
image(b)
The results are very different. I upload the array file and two figures.
  • b.zip
    b.zip
my code:
the first:
contour(b)
the second:
image(b)
I'm not a Matlab user, so I'm only guessing from the on-line documentation, but it may be that Matlab's image is treating your flat matrix as levels in the range 0-255 (or 63535). In which case, they are all to small to be distinguishable from 0. Try normalizing the data first - I've attached a Mathcad image (zoomed in slightly) to show what I mean (Mathcad converts reals to integers and shows a similar effect, which the function normalize overcomes)
Thank you. After nromalization, it is still different.
Oh, I got it. The y-axis is reversed.
You can use the imagesc() function instead of normalization. It will automatically set the scale range to the range of your data.
10K
  • · Replies 32 ·
