New Reply
Driving a car onto a semi while both are in motion
Share Thread Thread Tools
Jun19-12, 02:42 PM   #1
A debate I have long had with my father-in-law. Can someone please set the record straight on what would happen given the following scenario:
Semi truck travelling at 55 MPH with a ramp down on the trailer. A car accelerates to 60 MPH and drives up the ramp and into the back of the trailer.
a) Does the car move across the trailer surface at 60 MPH and thus zooming to the front once in contact.
b) The car continues gaining on the front of the trailer at 5 MPH, thus pulling in slowly.
c) Something else entirely.
Thanks!
Rex
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Jun19-12, 03:14 PM   #2
Recognitions:
Gold Membership Gold Member
Welcome to PF, Rexmaster.
Answer "b" is close, but not exact. Mythbusters performed the test a couple of years ago. Exiting the truck was equally painless.
Jun19-12, 03:43 PM   #3
K^2
Recognitions:
Jun19-12, 04:04 PM   #4
Without any experiments I would say that the car will move at 55+60=115MPH, relative to the ground, and at 5MPH relative to the truck. Is that right?
Jun19-12, 04:16 PM   #5
Quote by magicacid View Post
That is self-contradictory. If the car is moving at 5mph wrt the truck, how can it be moving at 115mph wrt the ground, if the truck is only moving at 55mph?
Keep analyzing.
Jun19-12, 09:08 PM   #6
Recognitions:
Much is going to depend on what the driver of the car does with the throttle as the car drives up onto the ramp.
If the driver doesn't lift off as the driving wheels leave the road for the ramp, then the engine will start accelerating the car relative to the truck. This will lead to the car ramming the cab of the truck from behind. If the truck's bed were long enough (several hundred feet) the car could accelerate from 5 mph to 60 mph on the bed of the truck, for a combined speed of 115 mph relative to the ground, before it smashed into the cab at 60 mph.
If the driver lifts off completely, the car will be coasting at 5 mph relative to the ramp. That might not be enough to get it to roll all the way up the ramp.
Jun19-12, 10:25 PM   #7
Quote by Nugatory View Post
Actually, what will happen is the engine will stall.
What Mythbusters showed is that the wheels of a car have very little angular momentum. The moment they are on ramp, they immediately slow to match the speed of the surface underneath them. So there's no lurch forward from that.
But you're talking about something different. You're talking about keeping the engine at high enough revs that it should immediately accelerate as-if-from-rest. Except that the wheels are virtually stopped while the engine is revving high. If you're ever been in a car when it comes to a very abrupt halt, most often what happens is the engine just stalls.
Jun20-12, 05:36 PM   #8
Yes, on a motorcycle for instance, the effect is noticed more. When the front wheel hits the ramp it is like applying the front brake. Once the rear wheel hits the motorcycle starts to accelerate.
Jun20-12, 11:07 PM   #9
Recognitions:
Quote by DaveC426913 View Post
With a stick-shift, feathering the clutch... It won't stall, that's what the clutch does. On the other hand the throttle setting that maintains a 60 mph cruise on the highway as we approach the ramp isn't going to be enough to accelerate us up the ramp... So I still believe that the original question was incompletely specified and the result will depend on what the driver does with the throttle (and clutch, which I should have mentioned as well).
New Reply
Thread Tools
Similar Threads for: Driving a car onto a semi while both are in motion
Thread Forum Replies
Circular Motion Problem with a Motorcycle Driving in a Sphere Introductory Physics Homework 23
Relative Motion problem driving me crazy Introductory Physics Homework 3
Centripetal Motion on a Semi-Rollercoaster Introductory Physics Homework 1
vectors and 2 dimensional motion, driving me nuts Introductory Physics Homework 2
Semi-hard Projectile Motion Problem. Introductory Physics Homework 9
