| New Reply |
Charging - discharging simple problem |
Share Thread | Thread Tools |
| Jun25-12, 05:25 AM | #18 |
Yes and out of it there is right cap which is totally uncharged before the closing the switch. so the circuit will look like the same ckt as you showed me.
And the P.D. across the right capacitor will become V/2 due to battery. M I going wrong? |
| Jun25-12, 05:36 AM | #19 |
yes the voltage across the two capacitors will be the same so long as the switch is closed (and will be the same as across the "second" resistor)
so what are the charges on each capacitor when the switch is first closed? |
| Jun26-12, 12:50 AM | #20 |
As the voltage across the two capacitors and the second resistor is same as V/2 then the charges on both the capacitors according the relation Q = CV are CV/2 & CV/2 ??? |
| Jun26-12, 01:55 AM | #21 |
the total charge has to be the same … impulsive current cannot flow through resistors (the maximum possible charge, ie the relation Q = CV, is irrelevant) |
| Jun26-12, 03:19 AM | #22 |
Do u mean to say that the charge on both will become CV/4 ?
| Jun26-12, 04:30 AM | #23 |
![]() does that make the rest of the problem clear? |
| Jun26-12, 04:49 AM | #24 |
OK.. I am getting this. But please tell me one thing: At the time of closing the the switch the right cap is connected with left capacitor hence the charge distribute equally on both. Bit the right cap is also connected to the battery at this instance so what is the role of battery at the moment?
| Jun26-12, 05:00 AM | #25 |
the battery and the resistors need time to do anything, but the charge rearranges itself "instantaneously" … comparing it with mechanics: the switch gives an impulsive force, and non-impulsive forces (such as gravity, or the battery) have no role |
| Jun26-12, 05:14 AM | #26 |
But some times when I solve some problems of charging- discharging, take the example of a simple circuit when a cap and a resistor are connected in parallel and a battery is connected with this circuit in parallel.
Many times the problem says at the instance of closing the switch : Current will have two ways on the junction of resistance and cap. but the current will flow through capa at that time, it acts like zero resistance or superconducting wire at t = 0 but the time goes on the cap stores charge by leaps and bounce and resistance of it keeps on increasing. And after a very long time when it gets fully charged it no charge flow through it, it acts like R→∞. Is this wrong, so please tell me what is the actual concept but mind one thing I've solved ample number of problem keeping this concept in my mind, If you want I can show you some examples. |
| Jun26-12, 05:28 AM | #27 |
Recognitions:
| Jun26-12, 05:35 AM | #28 |
![]() talking about the "resistance" of a capacitor is just an analogy a capacitor does not have a resistance (R), it has a reactance ie it is not Ohmic, with I proportional to V, it is reactive, with I proportional to dV/dt no, the charge flows smoothly … it starts fast, and ends slow, but the change is smooth immediately after you close the switch, the charge on the capacitor is still zero, but the rate of charge is non-zero |
| Jun26-12, 08:22 AM | #29 |
![]() Well I mean to say that at the instance of closing the ckt the current has two ways at point c, one from capacitor link and another from resistor through wire cd. So the resistance sorry capacitive reactance of the topmost capacitor is very less at this time hence the charge will flow form capacitor. |
| Jun26-12, 08:24 AM | #30 |
Friend please make me understand some according to this fig. Is this fig is correct. Will the ckt look like this?
| Jun26-12, 09:04 AM | #31 |
Recognitions:
What do you mean by "the topmost capacitor"?
| Jun26-12, 09:17 AM | #32 |
Look at the rectangular loop formed by the right and left capacitor.Apply Kirchhoff's Voltage rule.The capacitances being same they ought have the same charge initially.The left capacitor achieved steady state in the time before switch was closed ,true but now it has to achieve the steady state once again in accordance with Kirchhoff's rules. regards Yukoel |
| Jun26-12, 09:47 AM | #33 |
you're talking about problems with a resistor and a capacitor (or more than one capacitor) in parallel, so that the current (or charge) can flow both ways then yes, you're correct (apart from the "leaps and bounds"): the current (which before the switch closed was flowing entirely towards the resistor) will start flowing entirely towards the capacitor, but will then flow more and more towards the resistor until finally it flows entirely towards the resistor (as if the capacitor started with zero resistance, and ended with infinite resistance) |
| Jun28-12, 05:58 AM | #34 |
::Yukoel:: So like "tiny-tim" was telling me Its P.D. will become V/4 now so as the P.D. of the right capacitor. Is this correct?
| New Reply |
| Tags |
| capacitor charging, impulsive current |
| Thread Tools | |
Similar Threads for: Charging - discharging simple problem
| Charging and Discharging | Introductory Physics Homework | 5 | ||
| Charging and Discharging capacitor problem . | Introductory Physics Homework | 4 | ||
| Charging and discharging RC circuits | Introductory Physics Homework | 0 | ||
| Capacitor Charging/discharging problem | Engineering, Comp Sci, & Technology Homework | 5 | ||
| charging/discharging capacitor | Introductory Physics Homework | 1 | ||
