Incline shear blade formula to calculate cutting force
The discussion focuses on calculating the cutting force required to shear a 1200 mm wide and 3.5 mm thick metal sheet using an incline shear blade at a 1° angle. Participants suggest calculating the energy needed to shear the surface area by multiplying the thickness and width, then applying a constant force over the cutting distance. The thickness of the sheet is confirmed as 3.5 mm, while the width is 1200 mm.
  • Understanding of shear force calculations
  • Familiarity with incline shear blade mechanics
  • Knowledge of material properties related to metal cutting
  • Basic principles of energy and force in mechanical systems
  • Research the formula for calculating shear force in inclined blades
  • Learn about the impact of blade angle on cutting efficiency
  • Explore material properties affecting cutting force, such as tensile strength
  • Investigate energy consumption in metal cutting processes
Manufacturing engineers, mechanical engineers, and anyone involved in metal cutting operations will benefit from this discussion.
sameervyas
Hi ,
I want to calculate force required to cut a 1200 mm -3.5 mm sheet using incline shear blade.
Anyone know what formula we can use in this case when we are cutting metal on an blade angle of 1°.
Thanks
Please help.
sameervyas said:
Hi ,
Thanks
Please help.
One could calculate the energy required to shear that surface area (thickness * width), then apply a constant force over the distance. I presume 3.5 mm is the thickness?
Hi Astronuc,
you are right 3.5 mm is the thickness and 1200 mm is the width.
18K
