How does rotational acceleration affect different sized tires?
The discussion revolves around the physics of rotational acceleration as it pertains to bicycle tires of different sizes. Participants explore how tire size and mass distribution affect the force required to initiate rotation, considering concepts such as moment of inertia and torque.
  • Brian seeks to understand the relationship between tire size, mass distribution, and the force needed to start spinning a tire.
  • Some participants mention the concept of moment of inertia as crucial to understanding the dynamics of rotating objects.
  • There is a suggestion that the force required to initiate rotation is influenced by the mass distribution of the tire, particularly the placement of mass closer to or further from the axis of rotation.
  • Brian introduces the idea of "leverage," questioning how the radius of the wheel affects the force needed to set it in motion, especially when considering the number of rope wraps around the rim.
  • One participant discusses the torque equation, indicating that torque is the product of force and the distance from the center of mass, which is relevant to Brian's inquiry about the effects of radius and mass distribution.
  • Another participant provides a mathematical perspective on moment of inertia, noting that as the radius increases, the force needed to set the wheel in motion decreases, but this is countered by an increase in moment of inertia.
Participants generally agree on the importance of moment of inertia and torque in the discussion, but there are differing views on how to best conceptualize and quantify the effects of tire size and mass distribution on the force required for rotation. The discussion remains unresolved regarding the precise implications of these factors.
Participants have not fully defined the conditions of the scenario, such as the presence of friction or the specific setup of the tire and rope. Additionally, the mathematical relationships discussed may depend on assumptions about mass distribution and the system's configuration.
BrianD
Hello,
I'm hoping someone can help me understand the physics involved in a rotating object.
Imagine 2 bicycle tires of different sizes with string wrapped around the rims.
How would I describe or calculate which tire requires less force to start spinning, or the change in force necessary to accommodate different diameter tires?
I would also like to understand how to describe what a change in a tires mass distribution does to affect the force needed for startup. ie, what happens when weight is added near the center of the tire as opposed to around the rim?
My appologies for a very basic question. Thank you for your help!
Brian
Where is the bicycle wheel in your question? on a frictionless surface, in a gravity free place, the wheel is standing straight, lying on the floor?
Like Justin said, it's all basically in the mass moment of inertia and the rotational form of Newton's second law.
Hi BrainD, welcome to Physics Forums!
I take you're interested only in the force needed to bring the wheel into motion, ignoring friction forces acceleration of the entire bike etc. I don't know how much physics or mathematics you know so I advise you to indeed read up on moment of inertia. It is a concept related to mass, but it takes into account the mass distriution. You already noticed the effect that mass close to the axis of rotation is easier to give a certain cycles per second than mass further away from the axis. As you might know accelerating mass requires a force F which is proportional to both the acceleration a and the mass m by Newtons second law:
[tex]F=ma[/tex]
For circular motion of a rigid body a similar formula exists:
[tex]T=I\alpha[/tex]
Now the force is replaced by a 'torque' T, mass by the 'moment of inertia' I and acceleration by 'angular acceleration' [itex]\alpha[/tex]. If you really want to find the answer to your question I advise you to read up on all three of them (eg try 'googling' them).[/itex]
A second component
First off, thank you all very much for your help.
If I could trouble you help with one more aspect of this problem, as moment of inertia alone does not acurately explain what I've observed. I'll have to call this second component "leverage", although I'm sure that's not right, and am referring to the fact that as the radius of the wheel get's larger force applied to it's outside makes it easier to set in motion.
In the bicycle wheel example, the wheel is vertical (and here on earth, but I'm hoping friction is constant so I only have to consider 2 forces), and is only the tire's rim (no bicycle, and no rubber on the rim).
First, I'll wrap a rope around the rim 10 times, and pull the rope with a fixed amount of force to set the wheel spinning.
The next time, I wrap the rope around the rim 100 times (It's a very deep rim!), and pull with the same amount of force. In this case, I've increased the mass at the outer edge of the wheel to increase it's moment of inertia, but I've also increased the radius of the wheel (by wrapping more rope around it), making it easier to set into motion.
I guess what the question boils down to is, what is the proper name for this "leverage", and how can I look at and compare the effects of both in getting this wheel to start spinning?
Thank you very much for your help!
Brian
Lets consider an axially symmetric mass distribution. This is aproximately true in your case if you assume the wheel is much more massive than the rope one time around the wheel. This simplifies things considerably as it makes the moment of inertia much more simple and also we don't need to consider (much) the vector character of the involved quantities.
Torque:
In this case the torque needed is simply force times the 'arm', the point from the center of mass to the point you pull. [itex]T=rF[/tex]<br /> <br /> <b>Moment of inertia</b><br /> The definition is[itex]I=\int r^2 dm[/itex] If you think of all th mass distributed a distance R from th center of the wheel this is just [itex]R^2 M[/itex] But ofcourse it's not that simple and I will increase by adding mass, and also if you distribute the mass further from the center<br /> <br /> Now as I stated earlier the equation of motion (with \lpha the angular acceleration) is:<br /> <br /> [tex]T=I\alpha[/tex]<br /> <br /> So the force needed to set the wheel (radius R) in motion is:<br /> <br /> [tex]F=\frac{T}{R}=\frac{I \alpha}{R}[/tex]<br /> <br /> As you increase R the force needed to set the wheel in motion decreases, but at the same time I increases making it hardre to increase the angular acceleration. Thus describing the effect you mention...[/itex]
  • · Replies 30 ·
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 49 ·
9K
  • · Replies 60 ·
